One thing you might try is moving coil pack 4 to another cylinder and see if the code moves. After that do a plug swap and see if it moves. Do them separately not coil and plug together..
1 Disconnect negative battery cable
2 unplug wire connector
3 disconnect positive wire (the bigger wire) usually has a nut or bolt to hold it on
4 their will be 2 bolts to hold the starter in place that need to be removed. they will most likely pass through the trans bell housing and thread into the starter motor.
www.kia.ca/.../ownersmanual/2006_sedona_Owners_Manual_E...
Kia Motorsrecommended special tools, genuine Kia replacement parts and .... Room light main control switch.....3-123 ...... work properly, the power sliding door and ..... fuel only. • Check to make sure the fuel filler cap is securely closed after refu- .... roof, you have to reset your sunroof sys- ...... bulb check when you turned the ignition.
Most vehicles have the fuses listed in the owners manual in the glove box or buy you a service manual from a parts supplier like Advance, Oreily's etc. .
you need to burp the system lift vehicle so front wheels are higher then back and run vehicle with heat on and coolant resivour cap off for about 30 mins
Job is not too bad but engine and gearbox needs to be lifted to access removal of belt covers, are you handy with spanners also make sure fuel pump timing marks are set correctly
Most "common" cause is and engine misfire that causes unburned fuel to enter the converter and overheat/melt the catalyst. The converter is covered by 8yr/80,000 mile warranty for defects, and may be covered thru Kia. On a positive note we have a 2005 sedona shuttle van a work with 250,000 miles on it and qoing strong.
I believe there is actually an access panel in front of the second row seat behind the drivers seat that you can access the top of the tank, fuel pump and possibly the fuel filter. Lift up the carpeting and check. 1.Remove the fuel tank cap to lower the fuel tank's internal pressure.2.Locate access cover.3.Remove the fuel pump & fuel filter assembly installation screws, then remove the fuel pump & fuel filter assembly from the fuel tank.
