I work at a mining company. We require a new jaw crusher to carry on with our ongoing project. many suggest hiring a jaw crusher from a crushing service is cheaper than owning a own jaw crusher. is it really beneficial to hire from a plant hire company ?
I highly recommend you to hire a jaw crusher from a crushing service provider. It is indeed true that they are cost efficient and there are plenty more advantage. They reduce the money spent on equipment on long run. They take care of the transportation of the crusher and also they maintain and repair it if there is any fault. You can hire it only when you need and send it back when you don’t have any project. This can reduce your overall expense and save money.
http://www.wph.net.au/crushing-screening/ is a plant hire and crushing Service Company in Perth. If you are in need of a jaw crusher you can check them out.
With any plant hire services, it is generally best (and more cost-efficient) to go with a service that specializes providing the man power and equipment that are relevant to the needs of your job. You do not want to hire a generalized service and you also want to ensure the service you hire has experience. For example, if your job requires a dumper service then you probably do not want to hire a crane service, unless of course you require crane services for your job. If you really aren't sure, you can always shop around first and consult with a few different plant hire firms to see which of their services may be bet suited to your job.
The cost benefit against initial out lay will depend on the quantity of material to be crushed
If the process will be short term so 6 months, the hiring may be cheaper especially if the hire cost includes replacement of jaws ( they wear out or crack in use) and crusher maintenance
On the other hand if the process is a long term project the purchasing outright may be a better proposition as besides the tax benefit for capital expenditure, any repairs or replacement items also are tax deductible
the tax benefit cam be amortized over a longer period allowing for the benefit to be spread over several years
Lease purchase cost is deductible for each tax period and if the machine is properly maintained then there is a resale benefit at the end of the process.
There are special accountants that can guide you properly so speak to one of them
