Naxa Electronics Naxa Npd-702 7" Screen Portable Dvd Player Logo
No disk error in an almsot brand new naxa portable dvd player
Need help fixing a no disk error. The DVD player has been cleaned but that has not helped. When opened the dvd seems to not spin well and when I help push the spinner with no dvd it spins fine. I also checked the ums that is supplying the strength and its at about 2.75 not sure where adjustment screw is if that needs adjusting.
  • shadowchb Jun 15, 2015
    Hi Heather Robertson, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Such as what a "ums" is and what units the "2.75" is being measured in and where? Also, is this with factory DVD's or DVD-R's that someone else has recorded?
  • Heather Robertson
    Heather Robertson Jun 15, 2015
    it was the reading I got with a digital multimeter 2.75 ohms on the laser apparatus. This is with any kind of DVD I have tried to play.
4 Related Answers
A
Anonymous
  • Posted on Nov 17, 2007
SOURCE: universal remote
call for a factory remote at1-800-736-6837
Anonymous
  • 2992 Answers
  • Posted on Nov 18, 2008
SOURCE: hard to get dvd player to work
How old is the set? As the player's laser ages it becomes harder for it to read discs. Audio CD's don't have as much data and are formatted differently from DVD's so they are easier to read. This is one possible cause. Hope this helps!
rulds2008
Grand Canyon Tech
  • 3867 Answers
  • Posted on May 25, 2009
SOURCE: dvd player won't work or eject
try bestbuy geek squad?
Maybe you shouldlook them up
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Anonymous
  • 87 Answers
  • Posted on Jun 02, 2009
SOURCE: cd will not eject
Return to place of purchase, sounds like the motor just dosent work. Its unfoutunate because their warranty dosent cover your time and effort
Won't format new DVD-RW disks
i did everyting today to fix this. bought new dvds, name brands different, tried finding codes, called the number. trust me. try this. clean it. thats All i did. cleaned it with a dvd cd cleaning disc, the one with two little brushes on it, nothing special, ran it until i heard the beep, popped my dvd in, they all worked. everyone, im still recording. i ran it about four times. now, if you tried to burn a dvd, and got the error, throw that dvd away. because i tried about ten dvds. after i fixed it, THOSE dvds were no longer usable. dont know why. hope this works.
3helpful
Error: Bad disk
If you are using original discs and have the problem. Try with a cleaning disc and is still the same, check for calibrating the optic lens. About how much is the replace or the calibrating you have to ask on the repair shop or manuf. website. Sometimes, is better buy a new one because the technology moves so fast it makes the same technology disposable.
Hard to get dvd player to work
Wrong Disk Error: Nothing has worked
send it back under warranty, make sure u r using the right dvds, some only use + some -
My Portable DVD Player wont play
you may have a dirty dvd, these players are very sensitive. try cleaning it or better yet put in a new one. if that doesn't fix it, i'd say return it for another. good luck.
VCR Error Code H002
On my DVD-LV50, I was able to re-initialize and fix a different error (error code H05). It might work for you, too.
With no disk in the player, press and hold these buttons for 4 seconds:
  1. Back skip -- [ |<< ]
  2. Pause -- [ || ]
  3. Play -- [ > ]
The screen will go blank, then say "Initialized."
After that, it worked like new.
I hope that helps.
Dvd player error code h2
  2. Pause -- [ || ]
  3. Play -- [ > ]
I hope that helps.
2answers
DVD player issues
Most likely the dvd is dirty, scratched, or chipped. Try cleaning the dvd disk with a soft cloth (chamois works best). Look at the surface of the disk and if it is scratched lightly, dust and dirt particles, fingerprints, etc will cause refractions from the laser light in the dvd player, which is then read as an error by the dvd player. Cleaning it with a soft cloth will sometimes help.
If that does not work, hold the disk up towards a light source and look for light coming through from the other side. If this happens, the disk is unreadable and unrepairable as the data source has been corrupted.
Top Naxa Electronics Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Naxa Electronics Car Audio and Video Expert? Answer questions, earn points and help others
