If unit has a water dispenser, how does water taste? I've run across bell peppers that will emit a bad smell. Keep in mind 95% of all refrigerators circulate air from freezer to refrigerator side and then back. It continues to circulate air so bad produce from refrigerator side will get into freezer side and ice will absorb smell. First, dump all ice. Then line shelves in refrigerator side with newspaper, that absorb smells. You can even try kitty litter in small cups in refrigerator side. Bell peppers gives off that metallic smell and can take some time to get out of unit. Highly unlikely a motor is bad and you've already changed outside water line.
To improve the performance and longivity of your garbage disposal you should clean the iniside of the machine monthly. Gunk builds up inside of the disposal things suchas, grease, dirt, peels, etc... The following is extreemely effective in removing all types of material from your disposal and will also leave it smelling great.
FIRST STEP. GRAB (2) ICE CUBE TRAYS FORM THE FREZER.
CRACK THE CUBES FROM THE TRAYS AND PUT 6 TO 8 CUBES INSIDE THE DISPOSAL (THE DISPOSAL SHOULD BE OFF WHEN YOU ARE PUTTING THE ICE CUBES IN).
AFTER PUTTING 6 TO 8 CUBES IN THE DISPOSAL TURN THE UNIT ON AND RUN TILL THE CUBES ARE GONE. REPEAT THIS UNTIL BOTH TRAYS OF CUBES ARE USED UP.
AFTER THE ICE CUBES ARE GONE RUN THE DISPOSAL WITH HOT WATER RUNNING THROUGH IT FOR ABOUT HALF A MINUTE.
AFTER RUNNING THE HOT WATER THROUGH THE DISPOSAL PEEL A LEMON. DISCARD THE PEEL IN THE TRASH. PLACE THE WHOLE PEELED LEMON IN THE DISPOSAL WITH THE DISPOSAL TURNED OFF. START RUNNING HOT WATER AGAIN AND TURN ON THE DISPOSAL. RUN THE DISPOSAL UNTIL THE LEMON IS GONE. TURN OFF THE HOT WATER AND RUN COLD WATER THROUGH THE DISPOSAL FOR A FEW SECONDS AND TURN OFF.
The inside of your disposal is now sparkling clean and smelling good. If you use your disposal a lot do this cleaning once a month. If you don't use your disposal much do it every 3 months. Your disposal will work and smell much better. THANK YOU.
All ice is the same...at or below 32FH is ice, above 32FH it's water
Perhaps your ice maker is making very small ice cubes that melt faster then bigger ice cubes, if so the your ice maker needs to be adjusted too make bigger ice cubes.
when mine did that i got out the air compressor and blew all of the dirty and stuff off of the moter and low and behold it worked great but be carefully I tore a blade off the fan and now it runs alittle noisey. still makes great ice now I gonna find another fan blades. you need to unscrew the back to do this.
When was the last time you cleaned it by running ice machine cleaner through it. After a period of time algea, or slime will form on the chill plate where the ice is made. Sometimes its invisible to the eye, but it doesn't mean its not there. When this happens the machine will freezse the water, and when the ice tries to slide forward to the cutting grid, it catches on the chill plate. There are no sensors in the machine to tell it that this is happening and so the machine moves forward and starts running more water across the plate, which in turn runs across the ice caught on the chill plate melting it and using it as a ramp to fall into the bin melting the ice there as well. So, try cleaning it before taking any further steps, then if the problem persist feel free to get in touch.
If the fan in the refrigerator (evaporator fan) isn't working properly your machine isn't going to be as cold as it should be and your ice maker won't work properly as well. This is due to the fact that the ice maker has a sensor in it and it won't produce ice unless the sensor tells it is lower than 10 degrees F. A rule of thumb is if the condensor fan motor is running, which is the fan located by the compressor, than the evaporator fan should be running as well. Now, with that said, there evap fan is tied into what they call a bi-metal thermostat. Depending on the brand these sometimes go bad causing the fan not to run, but that wil cause it not to work at all. If its working intermitantly, than chances are the fan motor is bad.
hoshizakis make ice cubes depending on the amount of water in the sump. if you are starving for water the sump only partially fills in the fill time allowed . then it makes ice until the water is used up and the float switch drops and the cubes are little slices. you can adjust the size of cubes you want by raising or lowering the float assembley in the sump. if its to low the water rises and the float rises and tells the machine you happy with little slices. if you raise it up to max height you can max fill before float satisfies and max ice cubes. But if you are starving for water the time to fill will run out before the sump fills and cubes will be small no matter where you set the floats assembly. water starving can be due to crud in the water line, to small a water line, most hoshizes take a half inch line ,or a clogged water filter. if you suspect a filter take it out . if fill is drastically improved you need a new filter. be aware that starving for water on a hoshizaki will eventually lead to broken evap plates. big time expensive.good luck. i put in a new machine ruined by starving water and the new one made little chips of ice real quick. i finally pulled the filter out and voila! big cubes and great production.
Well it is making ice cubes alright just too thick right? I would give it a good cleaning with nickleguard and retry. If it is still doing the same thing I would replace the ice thickness switch.
Magic Chef Counter Top Ice Maker. just bought one. it seems to go through the cycle, but i noticed no water is getting pumped up to the tray. I looked through the back and the water tu be is 1/2 way, doesnt seem to pump water up. I may take it appart soon. Anyone have any luck?
I know it will be a pain but take it apart again and lube the metal shaft in the solenoid and the plastic slide with petrolium jelly, that should keep it from freezing up. It's what we do...
