The Child Lock button is the second from the right in the line of buttons below the LCD screen. Press and hold this button for at least 2 seconds (or until you hear the beep and the icon light goes out). With a number of appliances, I've found that it takes longer than indicated to release a child lock so hold the button until you hear the beep.
Hi, I have experienced this problem on several hotpoint machines with led display's. There is really only one solution for it! If there are no wires hanging off then the answer is in the board, And you will need to replace it. It is a non servicable part and cost around £40.00+++.
Good luck.....
Bearings faulty or another fault this model suffers from is the concrete balance weight retaining bolts shake loose, if it is the bolts tighten up as soo as possible.
Regards
Advisor
