2003 Jaguar X-Type Logo
Posted on Jul 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to change engine belts on a jaguar x-type 2003 3.0
SPEEDY CAR WORK SHOP
Level 2:
  • Jaguar Expert 489 Answers
  • Posted on Aug 14, 2009
Jaguar Expert
Level 2:
Answers
489
Questions
Helped
159838
Points
671
To Remove BELTS : Drive Belt :
Disconnect battery ground cable
Remove wheel and tire
Detach accessory drive belt
detention drive belt
detach accessory drive belt
Remove accessory drive belt
slacken the tensioner
remove accessory belt drive
Install in reverse order
WATER PUMP BELT : Remove battery tray
Remove water pump belt
De-tension water pump belt
Installation in reverse
Hope this is helpfull
5 Related Answers
Anonymous
  • 52 Answers
  • Posted on May 11, 2009
SOURCE: 2003 Jaguar S-Type, programming a key fob
If its a new key fob the only way you can program it is this the factory scan tool, u'll have to take it to a dealership for them to do this and they will charge you .5 hrs for labor.only x-types can be programmed without the jaguar software. Im guessing it will cost you between 40 and 50 bucks to have them program it.
Anonymous
  • 94 Answers
  • Posted on Sep 20, 2009
SOURCE: coolant and power steering fluid for 2003 S-type Jaguar
coolant is a jaguar special but power steering is standard atf (transmission fluid)
Anonymous
  • 233 Answers
  • Posted on Oct 28, 2009
SOURCE: Jaguar X-Type cam belt
These are chain driven. The only issue I have seen with these are the chain tensioners breaking. Generaly with chain driven engines, the chain will last the life of the vehicle, unless something like the tensioner or guide brakes. If it does break repairs can be fairly expensive.
Anonymous
  • 24 Answers
  • Posted on Jan 22, 2010
SOURCE: Timing/Cam belt replacement on a Jaguar X type
there is no belt, it a timing chain so no need to replace.
blustu
  • 279 Answers
  • Posted on May 31, 2010
SOURCE: 2003 jaguar s type what does p 1000 code mean
If the Dianosis test Code P1000 is flagged after DTCs have been cleared, all engine management OBD diagnostic monitor drive cycles HAVE NOT BEEN COMPLETED. See http://www.bluejag.co.uk for further details on this
2003 Jaguar s-type 4.2 -- Engine fault, parking brake fault and DSL fault- when slowing down and goes into limp mode. Have to shut off engine and restart. does this every couple of months or so and it is...
i have a jaguar s type 2003 and out of no wear it is writting to be park break fault and the park break does not working what i can do to solve this prob.
4helpful
How to Change alternator on 2003 jaguar
Hi!!
This instruccions are for supercharged and non supercharged engines, if your engine is not supercharged disgreggard steps 4 and 8
To replace the alternator, remove or disconnect the following:
1 Negative battery cable 2. Air intake assembly 3. Cooling fan assembly 4. Supercharger drive belt, if equipped 5. Accessory drive belt 6. Alternator air intake ducting 7. Alternator wiring connectors 8. Supercharger water pump, if equipped 9. Alternator Good Luck!! Don't forget to rate this post!!
2helpful
Suggestion for 2003 Jaguar X type and 1999 A6 Audi
Was looking at parts online and could not find a timing belt for the Jag. Did find the timing cover oil seal which makes me think it has a chain , not a belt so no worries. As always I could be wrong. The audi definitely has a belt , should be changed at 60,000 Miles / 100,000 Km. I have a passat with the 2.8 V6 and find performance is not great , nor is fuel economy.
The good and bad......... jag is newer , audi is lower mileage Both are slightly finicky and repair and maint would be more $$$ than more generic cars. Ignore carfax , it is an unreliable scam.
Take each to a mechanic of your choice for an inspection.
My personal opinion is it comes down to age. If you are over 45 go with the Jag , under 45 go with the audi. (lots of performance and apearance mods avail.)
9helpful
2answers
5helpful
2answers
Does the 2003, x-type, 3.0 litre 6 cyl. have a timing chain or a belt?
Jaguar 2000-06 Repair Guide - 2.5L Engine
Both; you have the accessory belt...
Fig. Accessory drive belt routing-X-Type with 2.5L and 3.0L engines
Fig. Correct installation position for timing chain-2.5L and 3.0L
For more details, you can visit autozone.com (free register).
I hope help you with this. Good luck (remember rated this help).
2003 JAGUAR S-TYPE, CHECK ENGINE LIGHT ON, HOW TO RESET CODE?
what are the codes? let me know and could try and help
Serpentine belt
Below the water pump pulley
1helpful
3answers
2002 Jaguar X-Type 3.0L Sedan 4D
I have a 2003 taurus with the same liter engine as your jag Ford has been making this engine since 1986 the only thing to worry about check the drive belt make sure transmission fluid has been changed and had all current oil changes and tune ups and also if I had found this deal before you did I would have a Jag :-)
Jammed seat belt
bet the belt is twisted pull back the rubber door seal and remove the top buckle should be possible to remove the trim pull the belt all the way out and untwist   go for it
Top Jaguar Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Jaguar Expert? Answer questions, earn points and help others
