is the motor getting hot? try lubricating the main bearings.sounds like dry bearings .farr64
SOURCE: blade broke where to get new one
You can call by phone Lasko customer Service and Replacement Parts......1-800-233-0268.......givi them FAN info and they will ship you part..........................Also check, your product may be covered under WARRENTY or may be listed under product recall .......either will reduce your COST .....
SOURCE: I have a Model #3510 Lasko Cyclone Fan and the blades are dirty
Steam works great, otherwise you can use a degreaser and hose it off. Make sure you let it dry completey and then some before plugging back in.
I’m happy to help further over the phone at https://www.6ya.com/expert/josh_87ce33216d7b2148
SOURCE: Cyclone 3520 by Lasko
first of all unplug while cleaning on .on the sides it should snap together r have clips on it pull apart r lift the snap hindges on hold the blade with 1 hand turn the knob with other clockwise i think wash r take a dust broom to it put back 2 gether
SOURCE: How do I take off to replace a lasko cyclone 3542 fan blade ?
Bex,
THose usually just pull off. You will have to pull hard because there is a spring clamp that they sometimes put around the inside hub of the fan. If there is a clamp, you will need to transfer that to the new blade. Hope this helps!
