T
Tim Mika Posted on Jun 13, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Does this unit have internal fusing that is replaceable? The tuner section is working but the the amp has gone black. No prior indications of problems..
Technics SA-GX700 Stereo Amplifier
johnny rebel
Level 3:
Top Expert:
  • Master 10,875 Answers
  • Posted on Jun 13, 2015
 johnny rebel
Master
Level 3:
Top Expert:
Answers
10875
Questions
0
Helped
2938438
Points
47944
Go to the back of the line,no info
1helpful
I have a zenithAKB36157102 REMOTE that I bought for a converter tuner and now after the hurricane, the unit isn't working. batteries are fine and unit is only two months old.
Check for bad batteries on remote. If still nothing, then remote unit has gone bad or the receiver section in converter tuner is bogus. Either one or the other.
Philips hts3565d
Make sure it is the amp section by connecting a known good amp to the record output of unit. If it does not work then the issue is with the front end or preamps of unit and not amp section.
Technics SU-X302 Problems
Greetings
Is there any indicator on or its all off?
anyway i will assume that there is none
1.check power fuse if blown.
2.check power transformer if there is any output voltage
3.check internal fuses
more information will give a better idea.
try these steps and hope this helps.
No sound from car radio
replace the radio it blew the internal amplifier
I have a fishman presys plus on board pre amp. it was working then suddenly no sound is coming out. The tuner is working fine. when i plug my guitar chord, the led light indicator blips one, which is...
This is an indication of an internal component failure. The unit needs to be sent in for service. It requires special tools and skill to service.
My Yamaha RX-V757 Receiver wont turn on at all, everthing has gone blank??? Help
There are internal fuses in this unit.
Check these fuses first.
If you find a fuse that measures open, and the glass isn't black or black/silver then simply replacing the fuse may do the trick.
Make sure you get an EXACT match for the fuses, some are slo-blow because of the power on surge it has to allow.
I have a Nuvo Grand Concerto System (NV-18GM) that I am setting up. I initially plugged it in to 240V mains power before realising I had to reconfigure a couple of internal wires (switching from the...
If the main amp section does not have it's own fuses, then the fuse might have blown, because the amp has gone. However I think it is highly likely that you have taken out the main amp, especially if it is a single IC that does all the work. You should try and determine if the amp section is getting power before replacing it.
TEAC AG-V3050 FM reception was fine and then quit. Checked antena with no results. Internal component? Fuse?
If a unit turns on it isn't a blown fuse. Does the tuner give you indications that it is or is not tuning a station? Change the FM Mode to Mono. You should at least be able to hear FM hiss if the tuner is alive.
It's a GE microwave. i'm just heating up something then it completely shut off
could have blown a fuse in it... the fuse is located in the control panel section and does require you to take apart... prior to this just make sure the breaker didn't trip to unit and you still have 120 volts to plus or plug something else into that plug to make sure it still works...if your going to investigate the fuse make sure you unplug the unit prior to working on it...there will be a 20 amp fuse inside the unit i would start there if you have power at the plug still......good luck
Jan 03, 2011 • Ovens
2helpful
4answers
No sound coming from deck
check the remote wire(the blue with white) is it giving 12 volts to the factory amp? some ford have amps that needs to turn on when the radio turns on.
 Grubhead
Grubhead
SmartAviator
SmartAviator
