CAR WILL NOT START IT WILL LIGHT UP BUT WILL NOT TURN OVER. RED LIGHT ON INSTRUMENT PANAL BLINKS
This is how go to your driver side inner fender first make sure you turn you r steering wheel all the way to the right now go back to your driverside in fender well remove the plastic guard from that the part facing the bumper now look up inside and remove the the negative post off your battery leaving it un-hooked for about 15 to 20 minutes now hook it back up just remember not to lock the power door locks with remote or with the lock switch its ok when when driving just remember to lock the doors after everyone else is out while the car is running then it just you in the vehicle with the engine running now lock all doors with the lock switch while the engine is still running now shut engine off take the key out open your driverside door by using door handle now manually push down driverside door lock knob remember to do this ever time or our alarm will be enabled again then you have to unhook the batterry again to go through the procedure again to disabling the alarm system again well have fun this works for me!!
You can't disable it. Newer Dodges have chips in the key. Older Dodges you could lock the car down and open the door with the key to disarm the alarm. Try both doors. The latch sensor in one door could be broken. If still no luck, you'll have to get it on a scanner to read codes. Code readers don't read security codes.
yes you can i own one i just did it with mine
this is how go to your driver side inner fender first make sure you turn you r steering wheel all the way to the right now go back to your driverside in fender well remove the plastic guard from that the part facing the bumper now look up inside and remove the the negative post off your battery leaving it un-hooked for about 15 to 20 minutes now hook it back up just remember not to lock the power door locks with remote or with the lock switch its ok when when driving just remember to lock the doors after everyone else is out while the car is running then it just you in the vehicle with the engine running now lock all doors with the lock switch while the engine is still running now shut engine off take the key out open your driverside door by using door handle now manually push down driverside door lock knob remember to do this ever time or our alarm will be enabled again then you have to unhook the batterry again to go through the procedure again to disabling the alarm system again well have fun this works for me!!
