Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
G
Greg L Posted on Jun 13, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is my Sony Grand Wega Consumer Electronics Control (CEC) compatible?
T.l. Moore
Level 2:
  • Expert 273 Answers
  • Posted on Jun 14, 2015
T.l. Moore
Expert
Level 2:
Answers
273
Questions
0
Helped
426316
Points
726
Consumer Electronics Control (CEC) What is Consumer Electronics Control (CEC)?
Consumer Electronics Control or CEC is a function that allows you to control multiple devices over HDMI using one remote control by having a secondary device receive commands from a primary device. Although CEC wiring is required for every HDMI port it does not mean that every HDMI port will have the function enabled.
If your device has the CEC function, this information will be located under your setup or settings menu.
To enable the function you will need to turn the CEC function on and then search for any devices that are CEC enabled that are connected to the TV.
Was this article helpful? 2 out of 4 found this helpful Have more questions? Submit a request
Related articles
How to make Sony Grand Wega KF 50WE620 screen brighter please?
Question edited for clarity.
Page 60 of the manual refers. The section in the menu is called 'Video'.
Manuals for KF-50WE620
Sony https://www.sony.ca > electronics > support > product
Find instruction manuals and brochures for KF-50WE620. ... require the software update recently announced for certain BRAVIA™ and Grand WEGA™ televisions ...
Sony https://www.sony.com > electronics > support > product
Why does it turn on, then off?
"HDMI-CEC", short for HDMI Consumer Electronics Control, is an HDMI feature many TVs and peripherals have.
If the TV is connected to an HDMI or a programmed remote is being used on the cable box the TV may be getting a second command via the HDMI cable.(CEC) Suggest disconnecting the HDMI cable and manually turning on the TV and see if it will remain on with just a blue screen, Try changing the input to antenna-DVD etc and see if the TV remains on.
You may need to check the settings in the cable box or DVD to change the auto control(CEC) feature. Or if you prefer controlling the TV via the cable box remote then you would not use the TV remote for turning on and off.
This can get very confusing because the TV and the DVD or the TV and the cable box will interact between each other. The problem can be more confusing if the components are not exactly compatible with the CEC. Also many remotes have the additional feature of controlling other components in your AV setup. Many times the operation is alternate action. So each cycle of the remote the TV changes state from on to off. If the two components are out of sync than one is on and the other is off. In that case not using the master on off of the remote but using the individual component setting allows for the two to be sync again. (both off or both on)
Why wont the tv pick up any HDMI input?
Hello. CEC stands for Consumer Electronics Control. This allows you to use one remote control to operate multiple devices that are connected with the HDMI cables. Since all of the equipment worked before the power surge, it is very likely it will work again. We just need to "reset" everything.
Start by unplugging all devices from AC power and disconnecting the HDMI cables. Assuming you are using the TV remote to control everything, pug the TV back into AC Power and turn it on. Go thru all standard setup on the TV as needed (set date and time, scan for channels, etc). Turn the TV off.
Connect the first HDMI device to AC Power, connect the HDMI cable and then turn on the TV and the HDMI device. Check to see if the remote controls both devices. If it does not, go thru the Setup options on the HDMI device (you may need to use the original remote control) and see if there are any settings that apply to the HDMI CEC settings (enbable or turn them on).
Repeat this for additional HDMI devices.
By unplugging both the controlling device (TV) and the controlled device (such as a Bluray/DVD player) and then reconnecting them in the correct order, you should be able to get all devices working on the same remote again.
8helpful
2answers
While I am watch a movie a message keeps popping up that says "Simplink please try again"
if you go into the setup on the t.v. and the options menu, you can turn the "simplink" off ...
1helpful
My Sony KF-60WE610 60" Grand WEGA LCD Rear Projection has no picture but you can hear the volume the shows playing. is the lamp light possibly not working?
Encompass Parts Distrubtion List all Parts and Boards need for this TV they also have Free Service Manual you can Print out.1-800-638-3328
For Lamp # XL2100u Call Mats Electronics $99.00
1-800-628-1118
You need to Replace your Lamp.
Sony Grand WEGA KDF-50WE655 50 in picture is dark
I had the same and replaced the lamp - made a big difference. Got the bulb on Ebay for $82.00 with free shipping. Just the bulb without housing, seller has instruction online for changing bulb - very easy. River Valley Electronics
Here's a link
http://cgi.ebay.com/XL2100U-XL-2100U-A-1606-034-B-A1606034B-LAMP-FOR-SONY_W0QQitemZ370154719357QQihZ024QQcategoryZ149975QQcmdZViewItemQQ_trksidZp1742.m153.l1262
Digital or Analog?
Click this link to get more info about you TV. Is HD compatible.
HD Video Recorder - CEC connection with HDTV
My first question would be, Is your Panasonic HD recorder CEC compliant? CEC means Consumer Electronics Control. That simply allows for the consumer to have better control over their Home Theater set up through the connection of you HDMI cable from their remote control without programing the remote control for every single device that is connected. If your recorder is CEC compliant the television should have automatically recognize the recorder and control you recorder via remote control (I am assuming that your recorder is an HD Camcorder, since your description was very vague). Once you connect your HD camcorder to your panasonic tv the tv should have turned on switching to the correct input and the same for any other CEC comliant devices. If your Panasonic HD recorder is not CEC compliant the you would have to start viewing your recorder the old fashion way, by using the recorder remote control or if your Toshiba remote is universal punch those codes in so that you can control your devices that way. If that don't work, try a different HDMI input and select the input and make sure your recorder is set to output on you tv. Hope this helps.....before I forget, check out this site to learn more about Consumer Electronics Control (CEC) http://www.videsignline.com/howto/207400325
Pink and Blue Spots
Sony guarantee the consumer to replace the optical block assembly for thousands of dollars in parts and labor every four years or when the pink and blue spots appear every time. Then replace the optical block assembly again and again every time the spots appear.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
