Health & Beauty Logo
charles laird Posted on Jun 13, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Replacement key for elite 8 scootet - Elite Health & Beauty
Thomas Smithbrother
Level 3:
Top Expert:
  • Master 3,698 Answers
  • Posted on Jun 13, 2015
Thomas Smithbrother
Master
Level 3:
Top Expert:
Answers
3698
Questions
0
Helped
957048
Points
10318
It is often easier and cheaper to take the lock off , take it to a locksmith and have a new key made for it. the put it back on.
www.monsterscooterparts.com/goeltrs.htm
How fo i cannect 5,12 voot batteries plus breaker to make it 60 volt for my electric scootet
Connecting 12 batteries in series would give slightly more than 61 volts. Considering that under load voltage will drop then it should be ok. Breaker goes between battery and motor on positive wire.
Dim screen, where is the key to turn up the brightness on hp touchsmart 9300 elite personal pc?
RTM? read the manual , at hp.com
https://support.hp.com/us-en/product/hp-touchsmart-9300-elite-all-in-one-pc/5060844/manuals
page 11, F11 is the hot key key for brightness UP.
the manuals for cheap HP are near toy grade, sad to see.
all-in-one = PC = cheap
it came with windows 8, did you upgrade to 10 and wreck all the drivers, as will be the case if done?
Where can I get a Manual for mega motion elite 8
This came from an Elite website but there's no brand ID in the link, so I don't know if it works
http://installldownload.com/d/
Use a search engine and type:
>mega motion elite 8 OWNER'S MANUAL<
Pick the correct choice and download.
1helpful
I have damaged the key for my go go traveler elite plus 4 . Can Iget a replacement key. It's the one thats built in to a plastic cover.
hi.
most scooter dealers should be able to order you a replacement key.
there are a couple on ebay as well at the minute.
a large headphone plug works as a key if you are really stuck.
hope this helps
2answers
I lost the safety key how can i replace it?
You can buy a replacement key from ICON Health and Fitness online or by telephone
Part # 264413
@ http://www.iconservice.com/CustomerService/parts.do or call 1-877-993-7999
hope this helps
3/8 Drill Driver, chuck replacement.
hi friend,
Step 1. Determine what kind of replacement drill chuck you want - a keyed chuck or key less chuck. Over the years, key less chucks have been widely used for handheld power tool drills, due to their improving grip torque and convenience.
Step 2. If you prefer replacement key less chucks, then you have to know what type of key less chuck you will need - a single sleeve key less chuck or a double-sleeve chuck. You can simply determine it by checking your current chuck. If your current chuck is a keyed chuck or a double sleeve chuck, then you will need a replacement double-sleeve key less chuck. On the other hand, if your current chuck is a single sleeve chuck, then you should get a replacement single sleeve chuck.
Step 3. Confirm the threaded mount size (spindle size) on the chuck. 3/8"-24 threaded mount for 3/8" capacity drill chucks and 1/2"-20 threaded mount for 1/2" capacity drill chucks, but there are some exceptions where just the opposite may occur. To be safe, always check the threaded mount before you buy replacement drill chucks.
hope this helps u
please rate me.........................
thank u for using fixya
regards
sivaranjini
2helpful
Replacement tires for 1978 GL-1000
I would recommend the K177 dunlops if you want to stick with the classic look on your wing.
but the Elite 3 is the current replacement for waht you have on the bike.
and the D404 is a real common, inexpesive and fully capable tire for just cruising in the city.
ive been working parts in a shop for nearly 8 yrs. and have had luck with all 3.
also might wanna check into a metzeller if your looking for high mileage out of a set of hoops.
get at me with any other ?'s you may have
2answers
Smith Corona HP1100
Hi..
usually there is a "CODE" key on the keyboard. This is to be held down while pushing the pitch key (10 -12- 15) may say Pica-Elite-Micro.
On some models there is a actual switch to move to the 10-12-etc.
I hope this is helpful and solves your Problem.
Squipps
Top Elite Health & Beauty Experts
Rob Hill
Rob Hill
jws1013
Paul Carew
Are you an Elite Health and Beauty Expert? Answer questions, earn points and help others
