Dear, first of all try cleaning the pins of your charger and mobile charging socket with petrol or kerosine oil. then see if it works, if still the problem persist, then their may be the fault in your charger or mobile charging socket. Or electric socket where you put your charger for charging! try charging your mobile by putting your charger in different switch board, if still it wont work, then try charging your mobile with different charger, if your mobile is getting charge, then get sure that problem is in your charger, its time to buy a new charger. original charges cost=900 duplicate charges cost=100
In case the battery is not getting charged. It can be due to 3 reasons
1. The power adapter through which you are tryiing to charge the battery is u/s Check with another adapter and see if its charging then the problem is with the charger else.
2. Take out the battery and put it on another phone and try to charge it. If it is charging then the problem is with the mobile charging point and not the battery. If not charging then the problem is with the battery only.
3. Mobile charging point is not working due to which the battery is not charging to check this out just put your battery on another phone and check if its charging. If charging then you are required to get your charging point on your mobile repaired.
hi. i am majeeb.i bought mobile samsung s 3653 twomonths ago .my mobile has charging ok.but charging not saved.plz send me solution on my email:[email protected].
To charge your mobile with usb cable you should install a driver called as mobile phone usb driver ,if you install it you can charge your mobile through PC.
If still it doesnt charges then install the PC CHARGING DRIVER.
I will give you the website which contains the driver and the instruction below it to install the driver so that you can charge your mobile by usb
Hi, It denotes that USB charging is not supported by uour mobile phone. If you are using the same socket in your mobile phone for charging whcih you are using for connecting your mobile to computer then there may be USB charging option available for your phone. If you are having separate charging Jack in your phone. Then USB charging option may not be possible. Please refer your mobile phone user manual to check whether the USB charging option is available or not.
i was charged my mobile k850i then one massage came my mobile seirious error,stop charging your mobile, stop using & plese contact sony ericsson call centre.
