Have a konica minolta magicolor 8650 with this message on the screen IU need to be replaces YMC , Only black printing possible , machine status 8/21 Can it be cleared?
replace the yellow print head which houses the LASER for the yellow drum print head is located below the yellow image unit (each color has one). It is a "######" to get out, recommend a tech do this.
Image unit end .You need replace the K =Black image unit,or enter in the service mode,open the front door,pull out the image unit K push the image unit select IU unit press the New release windows ,close the front cover and the copier must be ready to copy.
does this happen though the document feeder or on the main glass if printing was fine then black cartridge and drum are ok its the scanner roller replaced or there something causing a problem
Pleas check the imagine unit drum, is it clean or does there are the same marks as in paper.
if yes, the IU drum cleaning or drum itself is damaged and needs to be replaced.
Try:
after sending a print job, when printer has take a paper from tray, open cover, open cover before the paper enter the fusing unit, then you can see, if the mark is allready in the paper then the problem is in the IU or toner cartridge, if not, then fusing unit rollers.
