Question? Did you accidentally hit the sound button on it and mute it? If no then reset the unit and i don't mean power off, i mean use the reset button with a paper clip and try that should bring the sound back on for you and check the volume makes sure it is up.
Hope this helps
Probably a bad speaker, common problem with GPS units. Is there any sound at all, have you tried calling your cell phone to see if you can hear the rig through the GPS?
Try that and if you still can't hear anything it could be the speaker.
most GPS will drain in sleep mode unless on some slow charge. Everything is actualy working inside except the screen Like the TV standby.. no picture or sound but chews up the power
Maybe you accidently turn OFF or reduced the sound volume. Tap the screen to go to MAIN MENU, then tap the CHANGE PREFERENCES, you might find a speaker's icon with words TURN ON SOUND. Tap it. If still not working, check Volume Preferences to set the volume level of sound.
Hope it might help
I don't know if this will help any, but when I updated my recently purchased tomtom go 720 with the newest app (8.3) and the new voices, map, etc...the voice feature completely stopped working on my unit. Everything else was working fine except the voice. However, I had installed an 8 gig sd card into my tomtom and put all the updates on the sd card because I was running low on the internal memory. Bythe way, only the voice instructions were not working..it would still play mp3's through the internal speaker, so I knew it must be a software problem. After several days with no voice instructions, I then proceeded to re-format the sd card and start all over, as the problem appeared to be a software issue. After re-formatting the sd card, I removed it and installed the back-up file from my tomtom before I did the first update. This time, I deleted a couple of the voices in the update package, so that I would have enough room to install the updates to the internal memory. "Bam" now everything is working perfectly again. I believe for me...the tomtom was having trouble communicating with the new application that I had previously installed on the sd card. I hope this may help someone.
