Can the printer head be removed for cleaning, have tried cleaning fluids but the jets are still blocked
SOURCE: My Epson Styluss CX6600 won't charge
This may be very simple. Turn the unit off and lift up the top. On the forward side of the unit you will find a little 'slider switch'. This is the scanner unlock - toggle the switch back and forth several times and leave in the unlock position. Turn on the printer and all will be well.
SOURCE: Epson CX6600 Skips every other 5th line when printing
Run the print head cleaning routine from the printers driver or control panel. you may have to run it 3 or 4 times to regain all the lines.
SOURCE: How to remove print head of epson stylus photo r1800 BEWARE SPAM NUMBER +1-800-532-4187 BELOW
Had the same problem - but the print head is actually easy to remove.
1) Remove ink cartridges
2) Remove 3 Phillips head screws at the bottom of the cartridge housing. (looking down from the printer front - top left, bottom left, top right).
3) There are 2 small plastic tabs on a plastic bracket that secure the flex cable on the right hand side of the cartridge housing. Gently release the tabs with a small flat head screw driver.
4) Lift the print head straight up (don't pull on the flex).
There may be a release for the flex to separate from the print head. But I did not see one. Instead I poured 1/4" of Windex in the bottom of a small plastic container and soaked my print head for about 15 minutes (occasionally agitating).
Then put back in reverse order - be sure to seat the flex in the guide (top-back-right) of the cartridge housing before screwing down. Then run a cleaning or two to flush the cleaning fluid out of the print head. (I have a waste ink tank installed so I am not worried about dumping excessive ink into the waste sponges).
The differences was remarkable - though there was still slight banding - maybe should have soaked longer (1 hr perhaps?) - I may repeat if it remains an issue.
Additionally there were large solid deposits on the left side of the print head which were responsible for scraping heavier weight photo paper. These dissolved in the Windex too.
SOURCE: EPSON BX300F BLACK PRINT HEAD BLOCKED TRIED TO
If you've cleaned the heads, and swapped the cartridges then it doesn't sound too good.
if you do a google search for Epson Printer Repairers in google with your location so like Cambridge or whatever they'll need to take a look.
You could also check to see if its under warranty - put your serial number in here;
http://www.epson.co.uk/Explore-Epson/About-Epson/Technical-Services/Warranty-Checker/1227954741866
