Cell Phones Logo
Emmy Joyner Posted on Jun 11, 2015
Why won't my power button work?
Sometimes my power button works but most of the time it dont, what do I need to do?
2 Related Answers
Anonymous
  • 122 Answers
  • Posted on Jun 07, 2009
SOURCE: power windows and radio sometimes dont work
check the wire connections for propper connection sounds like they aren't making it all the way
Anonymous
  • 14553 Answers
  • Posted on Nov 01, 2012
SOURCE: power button on my rca tv wont turn on sometimes
A number of possible reasons for this---failing part in set or even bad connections on main board in the set----model listed is prone to going dead with high pitched squeel etc.
Optiplex 780 will not boot 1 3 lights blinking Power Button.
check power supply ,check on/off switch may need cleaning.
check fans are running ok and thay dont need cleaning.
1helpful
I have intermittent problem with two of the four rings - sometimes they work sometimes they don't
see this causes and proceed for fix it. God bless you
Surface Element Switch If the surface element won't work, and there is another element of the same size on the stove, try switching the elements. If it still won't work, the surface element switch is probably defective. The surface element switch can't be tested or repaired, it will have to be replaced.
Surface Element Board If a surface element won't work the surface element board might be defective. Each burner is switched on and off with the help of a relay on the surface element board. If one or more relays has failed the surface element won't work. If two or more burners fail at the same time, this is likely the problem. If only one surface element won't work and the element itself checks out to be good, the surface element board might be defective.
Coil Surface Element If the surface element won't work, the coil surface element might be burned out. Most coil surface elements can be pulled out of their socket and checked with an Ohm meter for continuity. If the surface element won't work, check to see if there is any visible damage to the coils. Also, check to be sure the element is pushed all the way into the socket.
Radiant Surface Element The most common cause when the surface element won't work is the radiant surface element itself. The radiant surface element - or heating element - can burn out similar to a light bulb. If the surface element won't work and it doesn't have continuity, it will need to be replaced. The radiant surface element is not repairable.
Solid Surface Element If the surface element won't work, and the stove has the solid surface element type of heat, it's likely that the solid surface element itself has burned out. The solid surface element works very similarly to other surface elements - inside there is a heating element that glows when electricity is applied to it. As it gets hotter, the heat is transferred to the solid surface element
Terminal Block If a surface element won't work, there may be a problem at the terminal block. The appliance has a power cord which is attached to a terminal block. Over time, the connections at the terminal block can fail and burn open. When this happens, normally all of the surface elements won't work. The solution is to replace any burned wires and replace the terminal block.
Loose or Burnt Wire Connection If surface element won't work, there might be a burnt wire supplying power to the surface element. Sometimes the wire supplying power to the element burns out right near the element itself. Check for this by just looking at the wires leading to the element. If they're burned out it is usually easy to spot.
Incoming Power Problem Although not as common, if the surface element won't work it is possible that the appliance is not receiving proper voltage. Electric ranges require 220 volts of alternating current. If for some reason the appliance is receiving significantly less, the surface element won't work. Check for proper voltage using a volt meter at the socket where the appliance plugs in.
1helpful
Monitor won't switch on properly.
This is a common symptom of failing filter capacitors in the power supply board. Over time as the capacitors start to fail they are not able to buildup and hold a charge like they should. The worse they get the longer the start time will be until one day the unit will not start up at all. The repair is easy to do, it just requires replacing the 5 bad capacitors on the power supply board. Here is a link to a parts kit that shows what needs to be replaced on the board.
http://www.ccl-la.com/catalog/product_info.php?cPath=21_33_68&products_id=222
I hope this helps,
BuddyMc
Sometimes nebulizer works ok during day and suddenly will not work, why?
could be the power supply is not efficient, or could be the filter needs to be changed try those, if none of what i said works i would send the product back and request a new one as thats something you dont want to not work when its needed.
I Have a 94 cherokee country with a 56028297 ecu,it has no power at the grey wire at the ecu,it does flash sometimes and I can hear the relay work sometimes. I can bypass the fuel pump relay circuit and...
If you hear relays clicking sometimes and the jeep won't start, at those times, is the check engine light illuminated on the dash, or not? If no check engine light is on the dash, at times when the jeep won't start, your ecu is in need of repairs. The ecu sends power to the ignition and fuel relays and when the ecu starts to malfunction, the relays usually start clicking.
2helpful
My compture workes sometimes and sometimes it dont.the power button was dented in after a rock fell on it. it seem like it may be a short in the power button . i am using the end of a pincle eraser to turn...
The motherboard has a pair of pins that is connected to the switch. The switch is a momentary contact, and when depressed the motherboard detects the momentary contact and starts up.
You can use any momentary contact switch as a replacement
Only power on/off button works, nothing else works.
there might be a problem with either your phone's software or hardware i dont see other reasons.
Power windows and radio sometimes dont work
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mike Cairns
Mike Cairns
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
