At first, I thought 'coil pack'. But you said it tried to start. So that's out. You might check that you're getting spark just to be thorough.
Did it ever start again after the stall on the interstate?
If not, I'm leaning towards the timing chain.
What happens if your timing chain broke:
- The timing chain no longer turns the cam(s)
- The cam(s) no longer open/close the valves
- The valves become stationary, remaining open or closed depending on the position of the cam(s)
- If even one valve is open in a cylinder, no compression.
- No compression, no start.
How do you confirm this without tearing apart your engine?
Do a compression test on all cylinders. If only one or two have compression (or one or more have zero compression), I'm tipping over towards the timing chain.
Have a compression test done.
Hope this helps
Mike
