Minn Kota Endura 36/36in Trolling Motor---- W/warranty () Logo
P
Phillip Fagan Posted on Jun 11, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Only works in Forward 5 or Reverse 3. Changed Forward/Reverse switch, still same problem. Any suggestions?
Vladimir Frolov
Level 3:
  • Master 2,075 Answers
  • Posted on Jun 11, 2015
Vladimir Frolov
Master
Level 3:
Answers
2075
Questions
Helped
415144
Points
6445
You've mentioned it's on warranty?!?! Call those guys!
I have an MTD husky 18-in rear tine tiller, my times turn backwards, but I have no forward or reverse in the transmission
There should be 5 positions for the gear selector.
Neutral
Reverse
Forward 1 wheels only
Forward 2 wheels and tines reverse rotation
Forward 3 wheels and tines forward rotation
If you have reverse tines only, then the problem is internal to the transmission. My guess is the wheel drive chain.
Nov 06, 2022 • Mtd Garden
Is there no reverse, goes forward but won't go in reverse
Outboard won't go into reverse ?? - General Discussion Forum ' In ...
www.in-depthoutdoors.com > ... > General Discussion Forum
Aug 9, 2006 - 8 posts - ‎7 authors
There's 2 cables that go into my outboard. ... It would have forward just fine but it would not shift into reverse. Assuming it's a wheel boat does the throttle handle go intoreverse but reverse doesnt work or does it not even ... Here are instructions to recover your old idofishing.com or idohunting.com account:.
Boat won't go in reverse - Lake-Link.com
www.lake-link.com/forums/boats-motors/.../Boat-wont-go-in-reverse
Sep 23, 2013 - 4 posts - ‎3 authors
Fishing Boards - Boats & Motors: Boat won't go in reverse. ... Forward seems to be working OK, but reverse just won't engage. ... I'm not sure if this is something at the throttle control end or something wrong at the motor. Any thoughts ... Looks like there'sa piece missing that's supposed to hold that in place.
Help! Will go in Reverse but not Forward gear! - The Hull Truth ...
www.thehulltruth.com/boating.../526873-help-will-go-reverse-but-not-f...
Jul 30, 2013 - 8 posts - ‎5 authors
Whether you're researching a new boat, or are a seasoned Captain, ... and it was notengaging fully into forward gear, but into reverse just fine. ... I'm a little dumbfounded as to why it will lock the prop when it's not running, but won't go into forward gear when it is ... While your there, change out the bellows. Mercury 125 won't go into reverse - The Hull Truth ...
Mar 17, 2014
Mercury 25 Horse Won't Shift into Reverse
Apr 5, 2009
90hp Yamha won't go in reverse & more - The Hull ...
Oct 4, 2007
Boat wont go forward or reverse - The Hull Truth ...
Jun 6, 2006
More results from www.thehulltruth.com
Dec 16, 2015 • Boating
Transmission trouble
Vehicle does not move forward.
The following parts and assemblies need to be checked thoroughly.
1. Manual valve
2. Valve body assembly
3. Forward clutch C1
4. Planetary gear unit
5. 1st and reverse brake (B3)
6. Park/ neutral position switch
Lionel o guage santa fe steam engine locomotive won't reverse even with reverse switch on?
You do not specify which Santa Fe steam engine you have, but I am going to guess it's the Santa Fe RTR O27 set...
Here's a link to the manual for it. Go to page 9, read the last paragraph on the page. It may be the answer to your problem
.http://www.lionel.com/media/servicedocuments/71-1900-250.pdf
Hope this helps.
Cadet LT 2042 worked fine changed hydro filter by lifting front with hoist to vertical. Lowered and topped off fluid. Now wont go forward or reverse. Makes no noise when pedal is engaged to move either...
You will have air in the system and will need purged. To do that you jack up the wheels to where they will turn freely then disengage the hydro and at an idle alternate forward and reverse for a for about 4 or 5 minutes. Recheck the fluid level and top off. Now engage the hydro and do the same forward and reverse for 3 or 4 minutes. You should have axle movement at this point. Hope this will help.
3answers
Runs only in reverse i have other pre war 1681e does the same
Have you changed transformers? You can also make a Lionel run in opposite direction by using the throttle control...just go to stop and then to power and then back to no stop and right to power. That often works.
2answers
MinnKota Endura 50 Runs only in high speed in forward and reverse
the coil pack is likely bad especially since you changed the switch. call minkota and get the bench tast info (very simple) and then order and replace the coil pack about 26 dollars. be very careful how you put the magnet assembly back together and mark the position of the case on the outside before disassembly. order a new seal kit and use locktite on the shaft again when reassemling to seal the shaft tube for water. dont run motor uout of the water much as it uses the water to cool the shaft and you can damage the seals. good luck.
8helpful
7answers
Shredder won't shred any more.
I have the Infoguard SX100M Axeus, sold by Staples.
Only the reverse was working, UNPLUG and open back cover, the paper mechanical switch was working fine, red side switch, the gears and fuse were all ok, I think something on the circuit board was fried.
I switched the BLACK and WHITE wires with each other going to the shredder motor, thus when I switched it to reverse, it would go foward and shred. Its working now, only in reverse.
Top Minn Kota Boating Experts
ADMIN Andrew
ADMIN Andrew
john h
vince
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
