Question about Garden
I need a user manual for my weed eater model no. UT20769
The machine is very hard to start; have followed the directions explicitly. Mixed gas correctly.
    Filmmaker:
    Uploaded 5 video answers.
    New Friend:
  • 106 Answers
Try switching to MotoMix fuel. Its high octane and premixed.
homelite weed eater ut20769 manual Bing images
Posted on Jun 11, 2015
  • ray gallant
    ray gallant Jun 11, 2015
    and quite costly too
  • Keith Poitier Jun 12, 2015
    it is costly. for me the cost was worth it relative to how much I used and the time and frustration I spent every time I tried to start it. Ultimately when mine finally broke last year I went to a 32V Worx unit. has a quick charge and two batteries.
    Top Expert:
  • Garden Master
  • 63,976 Answers
Try searching on Google for a manual
Testimonial: "I already searched on Google."
  • 1 more comment
  • ray gallant
    but I only see a model not a MAKE that might help us
  • ray gallant
    try a hotter spark plug or regap the one you have a little tighter .
  • ray gallant
    try this linkhttp://lawnandgarden.manualsonline.com/m...
SOURCE:
Toro manual weed eater model 51974
Jul 10, 2008 ... All Weed Eater brand gas trimmers require that oil be added to the gas in a ratio of 40:1,
You can Google these questions
Jul 06, 2018 | Toro Garden
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    Weed eater made a noise then just quit working, pull cord wont engage
    hello sir, Please provide the following information so that your issue may be diagnosed properly,what is it? brand name,complete model number The problem, What is happening with what? When it is happening? Are there times it does not happen? Did it just start happening? Did it ever work ? Did any seemingly unrelated event coincide with whatever it is not working? need the model number and brand name, if you need a manual i need the brand name and model number,if it is a riding mower the model number is under the seat.a snow blower the model number is on the rear of the machine, let me know,thank you. ~~ i need to know this before i can give you a answer,,
    Jan 23, 2012 | Poulan/Weed Eater No. Te475 952711797 17"...
    Describe your Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger Problem Need gas to oil ratio for poulan prolink pp335 weed eater
    I found the manual for this model weed eater, according to the manual the mixture...
    and I quote "This engine is certified to operate on unleaded gasoline. Before operation, gasoline
    must be mixed with a good quality synthetic 2-cycle air cooled engine oil designed to be
    mixed at a Ratio of 40:1 ...."
    and I quote once more from the manual "Helpful Tip. To obtain
    correct oil mix ration, pour 3.2 ounces of 2 cycle synthetic oil into one gallon of fresh gas."
    Hope that helps,
    If you like I can send the manual via email if you need it.
    :) happy weed thrashing
    Aug 12, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
    Do you add the oil first or the gas first?
    If you're talking about mixing two-cycle oil with gas for a two stroke motor, always mix it in a gas can then pour it in the weed eater. It's easier to put the oil in the gas can first then fill it with gas to get the two mixed well.
    Jun 16, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
    Weed eater TE475 - fuel ratio
    FUELING ENGINE
    WARNING:
    Remove fuel cap slowly
    when refueling.
    HELPFUL TIP
    To obtain the correct oilmix
    ratio, pour 3.2 ounces of
    2--cycle synthetic oil into
    gasoline. Before operation, gasoline must be
    air-cooled engine oil designed to be mixed at a
    ratio of 40:1. Poulan/Weed Eater brand
    synthetic oil is recommended.Mix gasoline and
    oil at a ratio of 40:1. A 40:1 ratio is obtained by
    mixing 3.2 ounces (95ml) of oil with 1 gallon (4
    liters) of unleaded gasoline. DO NOT USE
    automotive oil or marine oil.
    Jul 05, 2009 | Yard Machines Garden
    Need to add new string to a weed eater xt 12
      For manual go to;
      http://www.poulanpro.com/poulanpro/manualSearchPrepare.do;jsessionid=332BA6FC1EA2792C79A0A463204716AA
      Preparation Instructions
    1. Press the lock and rotate the spool counter-clockwise.
    2. Remove the locking ring if your weed eater has one.
    3. Take off the automatic feed button.
    4. Wipe away any debris.
    5. Push down on the spool to release the locking tabs.
    6. Remove the spool from the chamber. Restringing the Weed Eater
    7. Feed the line into the lower deck, traveling the line in an upside down J fashion (almost like sewing on a button but do not tie off the line). This secures the internal end of the line.
    8. Wrap the line following the directed arrows. Do this until it wraps to the depth of the chamber.
    9. Secure each of the lines into its own upper and lower deck grove settings.
    10. Install the spool back into its chamber.
    11. Pass the lines into the left and right holes and snap the spool into place.
    12. Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
    13. Reinstall the locking ring if necessary.
    Do it yourself repair: common repairs for a weed eater Amazingly, weed eaters are one of the simplest yard tools to take care of. One of the first things you should do to keep your weed eater in good condition is to clean it. It is important not to clean your weed eater with water or gas, which may destroy the engine. The best, and easiest way to clean it is by blowing off dirt and grass with an air compressor or a leaf-blower after every use. The next most important thing to maintain on your weed eater is string. When the string gets low you can remove the lower part of the head (the part that the string comes out of) by pushing in slightly and turning the head counterclockwise. Cut the new string no shorter than 6 inches or the weed eater will not advance the string properly when in use. Thread the string back though the guides, making sure to follow the arrows on the guide. If the string is not put through the guides the right way, the head may pop off during use. Next, replace the bottom of the head by pushing and turning clockwise. You can totally skip this step by buying a string replacement cartridge. Though it is much more expensive, it saves you the trouble of having to restring your weed eater yourself. window.google_render_ad(); If you find that the head of your weed eater is worn on bottom or hard to get off to replace the string then it is time to replace it. This can be done very simply by unscrewing the two screws at the top of the head and slipping it off. Then, just slide the new one on and tighten the screws. After a few months of use, you may find that your weed eater is losing power or that it is making a strange lower pitched noise. This may be caused by a dirty filter. To check, unscrew the knob or wing nut on the carburetor. Inside you will find a small square screen, this is the filter. If the filter is gray or black then it is time for it to be cleaned. The easiest way to clean it is to blow it out with an air compressor. It can also be washed with plain water, but you must let it dry before placing it back into the carburetor. Once the filter is white or only light grey it is ready to use again. Always make sure to mix the gas and two-cycle oil in the proportions that are listed in the weed eater’s manual. Never use anything but two-cycle oil, normal car oil will not work and will damage your engine.
    Jun 01, 2009 | Garden
    Do you use mixed gas for a ryobi weed eater??
    Unless it has a tag or decal on it saying it is a 4 cycle then it uses mixed gas/oil at about a 50:1 ratio. Straight gasoline will freeze the piston in the cylinder in mere minutes.
    May 23, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
    Garden Logo
    176 people viewed this question
    Top Garden Experts
    roeb
    john h
    Marvin
    Marvin
