Makita Tools 18V 1/2" Lxt Lithium - Ion Hammer Driver - Drill Kit - BHP451 Logo
Joe Bushard Posted on Jun 11, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What would be the most likely cause for my lxph05 brushless LXT hammer drill to intermittently not turn?
Here is what I know: The Battery is good The little LED light comes on when the trigger is pressed. It isn't being overloaded.
richie46
Level 3:
Top Expert:
  • Makita Master 12,962 Answers
  • Posted on Jun 13, 2015
richie46
Makita Master
Level 3:
Top Expert:
Answers
12962
Questions
Helped
2941540
Points
58151
Definitely a bad contact feeding power to the motor.
johnny rebel
Level 3:
Top Expert:
  • Makita Master 10,875 Answers
  • Posted on Jun 11, 2015
 johnny rebel
Makita Master
Level 3:
Top Expert:
Answers
10875
Questions
0
Helped
2938357
Points
47944
Replace brushes or blow out with air
Bill Boyd
Level 3:
Top Expert:
  • Makita Master 53,816 Answers
Bill Boyd
Makita Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11925307
Points
172802
Check the position of the forward/reverse switch as if it is not properly positioned the current doesn't know which way to spin the motor
check that switch for loose wire or being faulty
Milwakee m18 brushless fuel one key impact stop working all it does is keep flashing twice at a time the light on the driver that is,battery works fine on my hammer drill
probably the motor controller, brushless motors have a little computer that tells the motor when to activate each electromagnetic winding. The motors themselves are just bearings, windings, and magnets so they are fairly tough.
18v lith ion Battery charger 12v makita will not charge battery? why? why?
I also have the same dilemma,and of course,it occured 1MONTH after 1year warranty expired.I know my batts r still fine,as I recharge em on my foremans kit.
My charger plays a tune,then just blinks red,green....etc.Wish I had some tips to try,from an electronics brain-type person.......lol,good luck::
How can i replace the keyless chuck on my makita
I answered that question already on another post, but if you need to know how to remove the chuck I have detailed instructions in the TIP SECTION on how to do this. Let me know if you need more help
1helpful
My makita impact driver has lost power. it seems to be using the hammer much more and seems to be slipping. both the hammer and the andvil don't appear worn. the bushes are fine. what could be the problem?
This is more then likely caused by the plastic gears inside the drill wearing down. Makita may replace/repair under warranty depending on when you purchased the drill.
Hi my Makita LXT BHP452 has developed a faulty trigger. The trigger doesn't spring back all the way making it impossible to change to reverse mode/back again without pulling trigger out with your fingers....
JUST NEEDS A NEW SWITCH, EASY TO CHANGE WITH A LITTLE PATIENCE. YOUR LOCAL SERVICE CENTER CAN SELL YOU ONE OR WALK YOU THROUGH IT!! THE OTHER THING IT COULD BE IS THAT THERE IS A CHUNK OF DEBRIS IN THE TOOL OR THE HOUSING IS JACKED UP WERE IT HOLDS THE SWITCH INTO PLACE! I HAVE SEEN ALL SORTS OF THINGS HOLDING UP SWITCHES IN CORDLESS TOOLS!!!!! WORSE CASE IT WILL COST YOU AROUND $50 FOR A NEW SWITCH POSSIBLY ALLOT LESS. THANKS JIMS TOOL SERVICE
1helpful
2answers
Are the 1.5 amp (BL1815) and 3.0 amp (BL1830) interchangable?
i have both the hammer drill and impact driver and have been interchanging the batterys without any problems
Makita cordless driver drill model-6347d. ni-mh rechargeable nickel metal hydride battery 1834 18v 2.6ah will not stay charged. battery charter dc 1804- works great.
You say will not stay charged? Over what time period? Are you aware Nicad and NiMh rechargeables discharge naturally at 1% per day so where does that leave your power tool after 3 months? Furthermore they only have around 1000 charges in their useful life so you can immediately see how these tools are not for intermittent(ie handyman) use.
Problem with hammer drill
i'm afraid u have to replace your armatures..
Top Makita Drills Experts
Sean Wright
Sean Wright
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Are you a Makita Drill Expert? Answer questions, earn points and help others
