Battery issue: The battery in the keyboard may be faulty or have a low capacity, which can cause it to quickly drain and not hold a charge.
Charging issue: The charging port or cable may be damaged, preventing the battery from charging properly.
Keyboard software issue: There may be a software issue with the keyboard that's preventing it from charging correctly or retaining a charge.
Connectivity issue: The keyboard may not be compatible with your Samsung tablet, or there may be a Bluetooth connectivity issue that's causing the battery to drain quickly.
It is recommended to have the issue diagnosed by a qualified technician or customer support for the keyboard manufacturer. They can diagnose the issue and provide a solution to resolve the problem. Ignoring the issue could lead to further damage and increased repair costs in the future.
If you are in the Keyboard mode ... i.e., your iPad’s keyboard is showing on-screen, you shield see a button (icon) in the lower right corner that looks like a keyboard. Tap the icon. Your on-screen keyboard should disappear (toggle Off).
Once you connect the n4e keyboard, the virtual keyboard should disappear. Connect the keyboard using Bluetooth, be sure Bluetooth is turned on, and pair the keyboard.
T?Mobile US, Inc.Aug 11, 2013 - Please let us know because we want to make sure it's working for you. ... After opening the app I pressed "Force Stop" and then cleared the data. ... phone butthen i cant coz i cant type my password that is needed to reset it.
Go to settings.
Language and input.
Keyboard and input methods.
If google keyboard is your default, tap on the settings image.
Under General, there is an option called "Sound on keypress".
If checked, un check it and the sound will disappear.
Terry
Terryt
Go to settings.
Language and input.
If checked, un check it and the sound will disappear.....
