t's possible that the 5-year-old accidentally changed the input source on the Samsung TV, which is why you can't get the Fire Stick to work. Here are the steps you can follow to switch the input source back to the HDMI port where your Fire Stick is connected:
Turn on your Samsung TV and your Amazon Fire Stick.
Using your Samsung remote, press the "Input" button.
A list of input sources should appear on your screen. Use the arrow keys on your remote to select the HDMI port where your Fire Stick is connected. The HDMI port may be labeled as "HDMI 1," "HDMI 2," or something similar.
Press the "Enter" or "OK" button on your remote to select the HDMI input source.
Your TV should now switch to the HDMI input where your Fire Stick is connected, and you should see the Fire Stick's home screen on your TV.
If you're still having trouble, try unplugging the Fire Stick and plugging it back in to make sure it's properly connected. Also, make sure the TV and Fire Stick are both updated to their latest software versions.
Pair Firestick remote to TV
Go to Settings on your Fire TV. Select Controllers & Bluetooth Devices. Select Amazon Fire TV Remotes. Press and hold the Home button for 10 seconds to pair your remote.
When you used directv how did you get the signal? was it automatic? if so the firestick should work. Are you sure you getting power to the firestick. I have had problems in the past using the USB for Power that is on the TV. I always plug the usb power from the Firestick to an outlet instead of the USB power if available on the TV.
If yourAmazon Fire TV displays normally but you aren’t able to use any controls, first try troubleshooting the remote. For more information on troubleshooting the remote, go to Can't Pair a Fire TV Remote or Game Controller. Restart your device. Disconnect the power cord from the back of the device or from the power outlet, and then plug it back in. You can also use your remote to restart your device. Press and hold the Select Select Button and Play/Pause Play/Pause Button buttons at the same time, for about five seconds. Or, select Settings > Device > Restart from the Fire TV menu.
Make sure that you are using the power supply provided with your Amazon Fire TV device. Connect the included power adapter into the power port on the back of your Fire TV, then plug the other end into a power outlet. For Amazon Fire TV (1st and 2nd Generation), make sure that you are using a High Speed HDMI cable, if needed. The cable should say "High Speed", "1.3", or "1.4" on it. Plug one end of your HDMI cable into the HDMI port on the back of your Amazon Fire TV, then plug the other end into an available HDMI port on your TV. For Fire TV Stick, make sure that you use the included HDMI extender. If you are using an HDMI hub, disconnect your Amazon Fire TV device from the hub and try plugging it directly into the TV. Try switching to a different HDMI port on your television. Remember which HDMI port you used to connect your Amazon Fire TV device and switch to the corresponding input channel on your TV.
Typically you need to be in video feed for the HDMI port. On the remote, the button is usually called video or input. Press that button to get to your HDMI port. Then you should should see the Amazon fire stick feed.
Try an other setup code said for your device. Setup procedure and set up codes for many popular brand remote controls are given. http://electronicshelponline.blogspot.com/
http://electrohelponline.blogspot.com/
http://homenol.blogspot.com/
Plug the micro-USB power cable into your Fire TV Stick and the other end into the plug adapter and into the wall.
Plug your Fire TV Stick into an HDMI port on your TV (a cable is included to extend the HDMI reach if you've got a particularly tricky TV).
Next, turn on your TV and switch the input to the right HDMI port
You won't be able to interact with Fire TV Stick until you pair a remote. Thankfully, by just inserting the batteries into the included remote, it should pair automatically. If this fails, you can download and use the Amazon Fire TV remote app on your phone.
Now it's time to set up your wireless network. Fire TV Stick should automatically detect your Wi-Fi. Select your network and enter any passwords.
Your Fire TV Stick will then check for updates and download anything it doesn't have before letting you continue. Depending on how new your Stick is and the strength of your connection, this could take some time.
If you bought your Fire TV Stick from Amazon, it will have arrived already logged in and set up with your account, which is handy. If not, don't worry, it's very easy to set up a new account on Fire TV, requiring nothing more than your Amazon login details.
Once done, you'll be treated to an unskippable introduction to your Fire TV Stick, taking you through the basics of what the system can do and how to make the most of its features.
From here, you can set up parental control settings before you start using your Fire TV Stick as intended.
Amazon.com, Inc.It doesn't even play all the games that can run on the Fire TV box. Also note ... Q: CanI use my TV's USB port to power the Fire TV Stick? ... A USB port on your TV or other equipment probably will not work. ..... You can plug the Fire Stick's USB cable into theUSB port on your TV and it should work (depending on your TV ).
Amazon.com, Inc.Getting a brand new replacement from Amazon did not help, seems to be some other HW or SW issue. Anyone else run into similar issues? ... I also have a Samsung TV and the Fire Stick is not recognized through HDMI or USB connections. .... Can youplug the HDMI extender cable into your TV and will the Fire TV stick fix
You'll need to locate a second HDMI jack on the TV, or install a HDMI switch to manually select which device will be seen on the TV. Make sure you buy switch that has at least as many HDMI input jacks as you need now (and later, too!) to save you from having to buy another later. Here's what google returns:
