SOURCE: phone does not charge
When my phone is connected to the charger, it says fully charged. But as soon as I disconnect the charger, the battery shows empty. When I connect the phone to the charger, it starts charging but after 10 seconds it says fully charged.
SOURCE: warning bad connection charger
charger is broken...get a new charger or charge it on pc via usb cable provided....hope it helps you guys....
SOURCE: phone won't charge or hold a charge - tried 3
The problem with the phone is the charging port since you have use different charger and you have even change the battery and yet not still charging. it means the charging port of your phone is the problem.
All you need to do i to replace the charging port on your phone and you will see that your phone will charge.
Replace the charging port on your phone and your phone will start to charge, just change the charging and the problem is solved.
Take care.
SOURCE: Samsung galaxy tab will not
For most android platform products when you have "Mass Storage" turned on it wont charge. Its possible that the Car-USB charger isn't putting out enough juice to charge it in its on state. Could be to the quality of the car charger or that the car is already under strain from say a stereo or other devices being charged.
SOURCE: samsung galaxy Y pink wont charge
My samsung galaxy Y wont charge too. All i did was i just charged it and it reached 56% then unplugged it for me to use youtube. But then, my phone turned off. So i charged it again but it wont charge. What should i do? And, i already tried two chargers.
