If the exact answer using part number, from Kenmore or whirlpool, a good close answer can be found as
https://www.whirlpool.com › blog › washers-and-dryers › large-capacity-dryers.html Large Capacity Dryers | Whirlpool
Most standard dryers offer between 5.0 and 7.0 cubic feet of capacity. To help translate cubic footage into real-life laundry loads, consider that a 7.0 cu. ft. dryer can usually fit about 9-15 full-sized bath towels per load. Exact capacity varies by model so be sure to check the manufacturer's recommendations.
The third digit after the period usually indicates the capacity of newer Kenmore refrigerators. Since this is a bottom freezer with two door refigerator, it's probably a 20 cu. ft. model. If you have the original documentation, the energy efficiency label will have the capacity listed.
I hope this helps. To check, use a measuring tape to get the height, depth and width. Multiply the values together. If you measured in inches, divide by 1728 (12 x 12 x 12) to convert cu. in. to cu. ft.
The third digit after the dot usually provides the refrigerator's capacity. This suggests that the 106.9555711 is a 25 cu. ft. refrigerator. If this is an apartment-sized fridge, then it may be a 15 cu. ft unit instead.
The fourth digit after the prefix usually indicates the refrigerator capacity. It probably has 27 cu. ft. capacity. (If it is a small apartment size fridge would be a 17 cu. ft. model.)
Measure Exterior Height & Width and Depth for Dimension. Interior Space = Then, Measure all open accessible area inside the fridge and add the two together, following the formula of H+W+L Freezer and H+W+L Refrigerator,add together and BAM ya got cubic inches.= Square inches, then divide by 1,728 (the number of cubic inches in a foot (3) Cubed. Example 1: 60 inches tall, 42 inches wide, 30 inches deep = 75600/1728 = 43.75 Cubic Foot AREA Example 2: fREEZER dIMS = 24 DEEP x 18 HIGH x 36 WIDE =15552/1728 is 9 CuFt. Refridgerator 36 wide, 36 high 28 deep = 36,288/1728 = 21 CuFt. + 9 CuFt. = 30 Cubic Foot Capacity. By the Math Wiz RUDY :)
The cubic feet of the Kenmore washer model 110 heavy duty is 2.8 cubic feet. Measured to the top water line 14.5 inches and using the radius of the tub of 10.375 inches.
