It's filling up with water and will spin with the wash for 2/3 mins it will then sit there till the program reaches the spin cycle and spins fine on the spin cycle. No problems with water draining ect no lights flashing seems to be stuck any ideas?
???? ITS NOT SUPPOSE TO SPIN WHILE WASHING ? DO U MEAN ITS NOT AGITATING? THEN LOOK AT UR PRESSURE SWITCH AND UR CAM DOGS. MOTOR COUPLER OR BELT. NEXT UR CLUTCH BRAKE ASSEMBLY MAY BE BAD
My washing machine won't spin when in a wash cycle - washing-machine-spin-when-in-wash-cycle-dn3wi03dqy3vjnwbm4uf5us1-3-5.jpg03dqy3vjnwbm4uf5us1-3-5.jpg" alt="washing-machine-spin-when-in-wash-cycle-dn3wi03dqy3vMy washing machine won't spin when in a wash cycle - washing-machine-spin-when-in-wash-cycle-dn3wi03dqy3vjnwbm4uf5us1-3-9.jpg/images/washing-machine-spin-when-in-wash-cycle-dn3wi03dqy3vjnwbm4uf5us1-3-9.jpg" alt="My washing machine won't spin when in a wash cycle - washing-machine-spin-when-in-wash-cycle-dn3wi03dqy3vjnwbm4uf5us1-3-14.jpg class="h_mi" />
Typical control board issue. If heating is okay, if draining is okay. Aka your machine works fine. If the ONLY problem you have is the spin cyckle it is a issue with the control board. You can not change this yourself. It has to be programmed with a smart card writer. Does the machine display any errorcodes? (LED blink codes)
Kind Regrds Authorized Indesit (hotpiont) Technician
SOURCE: stuck in wash cycle
check if heating by putting on as hot wash and feeling the door. if no heat, check continuity thro the heater - modern heaters have a non-resettable cut-out in them which can cause problems. no heat then no program advance
SOURCE: Hotpoint WT540 1400 spin Washing Machine stuck on cycle
Could be a sticking water level switch, which controls the water level, or a blockage in the hose to the switch, or a trapped or split hose to the switch. the hose in question is about 6mm in diam,and goes from the sump hose to the pressure switch,if u remove the hose from the preesure switch chamber, check for a blockage there, and blow down the hose to see if it is clear, u should hear the switch click if it is clear, if no click and hose is clear, then I wud say the switch is faulty.
Plz rate my comments.
Thanks
SOURCE: WMA54 Hotpoint Aquarius drum does not turn during wash or spin
sound like the contact points on the timer are probebly dirty or arched to where they are not making good contact. you can take and clean them with a piece of emery cloth if you are mechanically inclined and can take the timer apart. Also there's a set of contacts down by the motor ti check too.
Good Luck,
SOURCE: I have the hotpoint BWM129 super silent 1200 spin,
The flashing lights means that an error had been detected.
The machine must be unplugged from main to check the drain hose and the drain pump.
The most common is that the drain pump is clogged with debris and must be unlocked.
