My display says loading factory resources but wont finish loading.
Found this on a Korg User forum, seems like what you're looking for:
The following procedure will reset your Pa800 keyboard to a known working state, without loss of user styles and sounds:
a) Save favorite styles and user styles into UserStyle.SET folders (MEDIA -> Save)
b) Save user sounds into UserSound.SET folders (MEDIA -> Save)
c) Reformat the SSD memory chip (wipes all user data) ... read the installation notes!
d) Load OS2.01 and MR2.01, which can be done in a single operation as follows ... read the installation notes!
e) Load the user sounds from UserStyle.SET folders (MEDIA -> Load)
f) Load the user styles from UserSound.SET folders (MEDIA -> Load)
NOTE 1: Do not use Korg's backup procedure using .BKP files. Many people have had problems because there is no effective mechanism when restoring from a .BKP file that avoids overwriting Korg's latest factory Musical Resources.
NOTE 2: Never overwrite Korg factory styles and sounds. This is because there is no effective way at the moment of saving and restoring your work in the event that a Korg Musical Resources update is issued in the future. Instead save any changes to styles in a Favorites bank, and save any changes to sounds in a User bank.
NOTE 3: Never load a .SET file containing someone else's GLOBAL or SONGBOOK subfolders. At best you will delete your own settings. At worst you will corrupt the memory of the Pa keyboard and things will stop working - then you will have to do the above "reset" procedure all over again to fix it.
Hope this helps!
I suggest a hard reboot / initialize. Istructions are in your manual or on the Korg website
