Televison & Video Logo
A
Asiya Hassan Posted on Jun 08, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My t.v has locked,how can i unlock? - Grundig GF70-600 TV
Level 3:
Top Expert:
  • Grundig Master 76,851 Answers
  • Posted on Jun 08, 2015
Grundig Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14994994
Points
237762
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Unlock procedure and to override the password lock to many popular brand TVs are given. Type in the brand name and type of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Door lock receiver on a2001 Pontiac Grand am
Do they work with the key fob, do you have one of those? They lock when put into gear an unlock when put into park because the BCM - body control module does that .
Door Lock System Components
The power door lock system consists of the following components:
• Driver door lock switch
• Front Passenger door lock switch
• Body Control Module (BCM)
• Relays: Driver Door Unlock -- on vehicles with RFA, Door Unlock, and Door Lock
• Door Lock fuse 15A
Door Lock System Controls
The power door lock system can be controlled by any of the following:
• A power door lock switch activation
• A keyless entry command -- if equipped with keyless entry
Driver and Passenger Door Lock Operation
When any of the door lock switches is pressed to the lock position, the BCM door lock/unlock signal circuit changes from an idle voltage of ~3.4 volts to 0.0 volts generating a lock command. The BCM then applies battery positive voltage to the Door Lock Relay, which in turn applies battery positive voltage to the Door Lock Actuator lock circuit of all the Door Lock Actuators. Since the Door Lock Actuator unlock circuits are held to ground through the resting Door Unlock Relay(s), the actuators execute the lock command, locking the doors.
The lock function can also be accomplished by the BCM having received a keyless entry door lock command, if the vehicle is equipped with keyless entry.
Driver and Passenger Door Unlock Operation
When any of the door lock switches is pressed to the unlock position, the BCM door lock/unlock signal circuit changes from an idle voltage of ~3.4 volts to ~1.7 volts generating an unlock command. The BCM then applies battery positive voltage to the Door Unlock Relay and the Driver Door Unlock Relay when equipped with keyless entry, the relay(s) in turn apply battery positive voltage to the Door Lock Actuator unlock circuit of all the Door Lock Actuators. Since the Door Lock Actuator lock circuits are held to ground through the resting Door Lock Relay, the actuators execute the unlock command, unlocking the doors.
The unlock function can also be accomplished by the BCM having received a keyless entry door unlock command, if the vehicle is equipped with keyless entry. Keyless entry personalization allows the driver door to be unlocked individually before unlocking the passenger doors. When this feature is active, the BCM will require a repeated unlock command to unlock the passenger doors.
Automatic Door Lock/Unlock
The automatic door lock/unlock function is a Vehicle Personalization feature with the following four programmable modes of operation:
The automatic door lock feature is disabled.
All of the doors lock when the vehicle is shifted out of Park with the ignition ON.
All of the doors lock when the vehicle is shifted out of Park with the ignition ON, and all of the doors Unlock when the vehicle is shifted into Park.
All of the doors lock when the vehicle is shifted out of Park with the ignition ON, and only the driver door Unlocks when the vehicle is shifted into Park.
For information on programming the automatic door locks, refer to Vehicle Personalization in Personalization.
1helpful
2010 Equinox doors keep unlocking after the car is parked killing the battery
Could be any number of thing's causing this problem . Knowing what all is involved in the locking an unlocking of the doors is key . Computer controlled by the BCM - body control module , relays ,wiring ,switches etc... Bad input from switch or grounding wire to the BCM could make the BCM think door unlock has been requested .
• Driver door lock switch--Provides a switched voltage signal to the body control module (BCM) for both lock and unlock switch activations.
• Front passenger door lock switch--Provides a switched voltage signal to the BCM for both lock and unlock switch activations.
• Door lock relay--Located in the instrument panel (I/P) fuse block and controls the locking of all doors and liftgate.
• Door unlock relay--Located in the I/P fuse block and controls the unlocking of the passenger doors and liftgate.
• Driver door unlock relay--Located in the I/P fuse block and controls the unlocking of the driver door.
• BCM--Class 2 module which requires programming when replaced
• Reversible door lock actuators in each of the doors
• LOCK/MIRROR 10 A fuse--Located in the I/P fuse block, supplies power for the door lock switches and relays.
• DR LCK 20 A fuse--Located in the I/P fuse block, supplies power to the relays
• Power door lock switch activation
• Keyless entry lock or unlock command
• Delayed locking command
• Automatic door lock command
• Lockout prevention command
• An air bag deployment
Door Lock and Unlock Operation
When a door lock switch is activated in the lock or unlock position the body control module (BCM) will receive a voltage signal on either the door lock switch lock or unlock signal circuits.
The BCM, upon receipt of a lock switch lock or unlock signal, will switch the appropriate lock relay control circuit(s) to battery positive voltage. This will energize the appropriate lock or unlock relay(s). The relay will supply voltage to the door lock actuator lock or unlock control circuits to one side of the lock actuator. Since the opposing side of the lock actuators are connected to ground through the other lock actuator control circuit and the normally closed contacts of the lock or unlock relay, the doors and liftgate will then lock or unlock appropriately.
Three relays are used to operate the lock. Driver door unlock, passenger door unlock and all door lock. This is done to isolate the driver door lock actuator so it can be unlocked by itself using the keyless entry transmitter.
Automatic Door Lock Operation
This body control module (BCM) controlled feature can be personalized to driver preference.
The BCM will automatically lock the vehicle doors if the following conditions exist:
• All vehicles doors are closed.
• The ignition is in the ON position.
• The vehicle is shifted out of PARK.
The BCM will then unlock the doors when the ignition is placed in the OFF position.
The first thing ,hook up a professional type scan tool an check for DTC'S in the BCM
DTC Descriptors
DTC B3140 00: Driver Unlock Switch Circuit
DTC B3145 00: Passenger Unlock Switch Circuit
DTC B3150 00: Driver Lock Switch Circuit
DTC B3155 00: Right Front Lock Switch Circuit
DTC B3130 00: All Door Unlock Circuit
I have a 2008 Chevy Malibu inside door locks don’t work like theirs no power no does not click on inside to lock when you’re in the car nor outside when you put the key in the outside lock it only locks...
Probably not a whole lot your going to be able to do ,Unless you have a factory or some other professional type scan tool to check for DTC'S - diagnostic trouble code's , an have service repair info for power locks for your car . Computer controlled (BCM) - body control module .
The Power Door Lock System consists of the following components:
• Body control module (BCM)
• Reversible door lock actuator in each of the doors
• IBCM (PWR) 15-amp fuse
• Driver door cylinder switch, if equipped
The Power Door Lock System is controlled by the body control module (BCM) and can be activated by any one of the following:
• A door lock switch lock or unlock actuation
• A keyless entry transmitter actuation
• An automatic door lock or unlock actuation
• A last door closed locking (LDCL) actuation
If the driver door cylinder switch feature of the vehicle is functional, the locks may also be operated by a driver door cylinder switch lock or unlock activation
Power Door Lock Switch Operation
Each door lock switch is wired to the body control module (BCM) through a separate door lock/unlock signal circuit. While these circuits are separated between the BCM and respective door lock switch, they are connected into a single circuit within the BCM. The BCM supplies voltage through the door lock/unlock signal circuits to each door lock switch. When either door lock switch is operated, this supply voltage is pulled to ground, providing the BCM with the required lock or unlock signal. In order for the BCM to distinguish between a lock and unlock signal, the lock switch contains two separate paths for this voltage to flow to the same body ground. When the switch is operated to the unlock position, the supply voltage flows to ground through a 1.5 K? resistor. When the switch is operated to the lock position, the supply voltage flows to ground through a different part of the switch circuit, which has no resistor. The BCM then interprets the flow of voltage as a lock or unlock request and powers the door lock actuators to the appropriate lock or unlock position.
Power Door Lock Actuators
The body control module (BCM) powers the reversible door lock actuators by providing battery positive voltage and ground to the appropriate lock and unlock control circuits of the actuators. The Lock control circuits of the driver and passenger door lock actuators are all connected together, however, the Unlock control circuits are connected in a slightly different way. While the unlock control circuits for the passenger door lock actuators are connected together, the driver door lock actuator has a separate unlock control circuit. The system is designed this way so that the keyless entry transmitter may be used to unlock only the driver door. Despite this difference, all of the lock actuators perform much the same way. When the door lock actuators are not active, all actuator Lock and Unlock control circuits are at ground potential within the BCM. Transitioning of the lock actuators to the lock or unlocked position depends upon which control circuits receive voltage and which control circuits receive ground.
• If the BCM is commanding the door lock actuators to Lock, it momentarily switches the lock control circuits to voltage. Since the unlock control circuits are at ground potential within the BCM, the actuators transition to the Lock position.
• If the BCM is commanding all door lock actuators to Unlock, it momentarily switches the unlock control circuits for both the driver and passenger door lock actuators to voltage. Since the lock control circuits are at ground potential within the BCM, all lock actuators transition to the Unlock position.
• If the BCM is commanding only the driver door lock actuator to Unlock, it momentarily switches only the driver door actuator unlock control circuit to voltage. Since the lock control circuit is at ground potential within the BCM, the actuator transitions to the Unlock position.
Power Door Lock and Unlock Operation w/Keyless Entry Transmitter
The keyless entry transmitter may be used to unlock only the driver door. When the unlock button of the keyless entry transmitter is pressed once, the body control module (BCM) receives the unlock request from the remote control door lock receiver (RCDLR). The BCM interprets this single press as an unlock driver door request and responds by switching only the driver door lock actuator unlock control circuit to voltage. With the lock actuator lock control circuit for the driver door at ground potential within the BCM, the driver door lock actuator transitions to Unlock.
If the unlock button of the keyless entry transmitter is pressed a second time within three seconds of the first press, the BCM interprets this second press as a request to unlock the passenger doors and responds by switching the passenger door unlock control circuits to voltage. With the lock actuator lock control circuits at ground potential within the BCM, the passenger door locks transition to Unlock.
To lock all doors with the keyless entry transmitter, a single press of the transmitter lock button is all that is ever needed. The BCM receives the lock doors request from the RCDLR and responds by switching all lock actuator lock control circuits to battery voltage. With the actuator unlock control circuits at ground within the BCM, all actuators transition to Lock.
1helpful
Where are the fuses for the power dock locks on a 2006 montecarlo06ss
DR/LCK fuse 25 amp . located in the I/P block
Fuse Block - I/P
In the right front kick panel
Power Door Locks System Components
The power lock system consists of the following components:
• Driver door lock cylinder switch
• Front passenger door lock cylinder switch
• Door lock actuators in each of the doors
• DR LK Fuse 20-amp
• A door lock cylinder switch unlock actuation
• An automatic door lock actuation (Personalization function)
• An automatic door unlock actuation (Personalization function)
Door Lock Operation
When the body control module (BCM) detects a transition of either of the door lock switches to the lock position, it switches the door lock actuator lock control circuit to voltage. Since the lock actuator unlock control circuits are at ground potential within the BCM, the door lock actuator motors transition to the lock position.
Driver Door Unlock Operation
When the body control module (BCM) detects a transition of either of the door lock switches to the unlock position, it switches the driver door lock actuator unlock control circuit to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the left front (LF) door lock actuator motor transitions to the Unlock position.
The driver door lock actuator unlock control circuit is a dedicated control circuit used only for the driver door lock actuator motor. This is done so that the driver door may be unlocked by itself using a keyless entry transmitter or an automatic door unlock function (if programmed).
When the body control module (BCM) detects a transition of either of the door lock switches to the unlock position, it switches the door lock actuator unlock control circuits to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the passenger door lock actuator motors transition to the unlock position.
The door lock actuator unlock control circuits are dedicated control circuits used only for the passenger door lock actuator motors. This is done so that the driver door may be unlocked separate from the passenger doors using a keyless entry transmitter or an automatic door unlock function (if programmed).
2005 Buick Rendezvous you can hear the relay clicking but the door locks will not open and close
Check for broke wires inside the boot from body to driver door , this is a common problem . If you don't find broke wire's , pull the door panel to get at driver door switch . Check for voltage an ground circuit .
Rendezvous Door Lock System Components
Door lock system fuse into the BCM (BCM D 25A fuse)
Door Lock Operation
When the BCM detects a transition of either of the door lock switches to the LOCK position, it switches the door lock actuator lock control circuit to voltage. Since the lock actuator unlock control circuits are at ground potential within the BCM, the door lock actuator motors transition to the Lock position.
When the BCM detects a transition of either of the door lock switches to the UNLOCK position, it switches the driver door lock actuator unlock control circuit to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the LF door lock actuator motor transitions to the Unlock position.
When the BCM detects a transition of either of the door lock switches to the UNLOCK position, it switches the door lock actuator unlock control circuits to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the passenger door lock actuator motors transition to the Unlock position.
The door lock actuator unlock control circuits are dedicated control circuits used only for the passenger door lock actuator motors. This is done so that the driver door may be unlocked seperate from the passenger doors using a keyless entry transmitter or an automatic door unlock function (if programmed). This video on testing computer controlled door locks on a Subaru , doesn't matter . test yours same way > The BCM controls your door locks .
Are all of the power door locks inoperative from both door lock switches?
1helpful
2answers
2005 Chevy Equinox Driver & Passenger Door Unlock Relay. How To Remove & Install. They Are Power Locks. Front Doors Must Roll Windows Down Use Hand To Open Thanks. Ms. J. C.
When a door lock switch is activated in the lock or unlock position the BCM will receive a voltage signal on either the door lock switch lock or unlock signal circuits.
Your door locks are controlled by the BCM - body control module (a computer ) . An a scan tool is a must to diagnose system operation . Your best bet would be to take your vehicle to a qualified repair shop . The only way you could try to fix this is by changing parts ! Suppose you find an replace a door lock/ unlock relay an that doesn't fix it ? There could be DTC'S stored in the BCM . Do you know what a DTC is ?
DTC B3132 All Door Unlock Circuit Low
DTC B3133 All Door Unlock Circuit High
Your
Passenger door locks don't unlock.
You need to understand how they work , do you know about automotive electronic controls ? Your switches are just inputs to the BCM - body control module !
Door Locks Power and Ground
For door lock operation, the IP Fuse Block supplies battery positive voltage, through the 15 amp DR LK/TRUNK fuse, to the BCM. The BCM uses this circuit exclusively to apply power to the door lock actuators. The BCM is also supplied a ground circuit, which it uses exclusively to ground the door lock actuators. When a door lock is pulsed, the BCM internally connects these two circuits to the appropriate lock and unlock control circuits to actuate the locking or unlocking functions.
When diagnosing door lock malfunctions, these circuits must not be confused with the other battery voltage and ground circuits of the BCM. The appropriate wiring schematic must be used to locate the correct circuits. Failure to identify the correct battery voltage and ground circuits of the BCM during diagnosis of door lock concerns may result in misdiagnosis and unneccessary parts replacement.
When the BCM detects a transition of either of the door lock switches to the Unlock position, it switches the door lock actuator unlock control circuits to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the passenger door lock actuators transition to the Unlock position.
The door lock actuator unlock control circuits are dedicated control circuits used only for the passenger door lock actuators. This is done so that the driver door may be unlocked individually before unlocking the passenger doors using a keyless entry transmitter or an automatic door unlock function, if programmed. When the keyless entry transmitter is used to unlock the passenger doors, the BCM requires a repeated unlock command before it performs the unlock function. However, when the unlock input is from a door lock switch, a single unlock command is all that is required to unlock all doors.
How to test computer controlled door locks
My 42 FD 9954 Philips flat TV monitor has a channel lock I can't get it unlocked what do I do
How to lock or unlock channelsTo lock or unlock channels:
  1. Press the Menu button on your remote control.
  2. Select Settings.
  3. Highlight System and press OK/Select.
  4. Select Parental/Purchase.
  5. Enter your Parental Controls PIN.
  6. Select Parental Preferences.
To lock or unlock all channels:
Select Lock All or Unlock All and press OK.
To lock or unlock specific channels:
Select Block by Channel > Add or Remove Channels.
From there you can select to Lock All, Unlock All, or
select specific channel(s) that you'd like to lock or unlock.
Why wont my phone unlock
What method you have used to unlock it .It's locked to network or security.If it's locked with security code use default codes to unlock it.Default codes are 12345 or 1234 or 0000.If these codes do not work get free master reset code for Nokia DCT phones from the site Unlock-free.com and reset it. You need to unlock it from network lock use correct unlock code.I think you may used wrong codes to unlock it or it may be a cdma network locked Nokia phone.CDMA network locked phones cannot be unlocked.Visit the site Mobile-unlocker.com get the unlock code for all GSM network locked Nokia phones and unlock it from service provider lock.After unlock it you can use with any GSM network sim card in it.
1helpful
Driver side door locking with remote but will not unlock, if i unlock it with key then remote will unlock all other door, if all doors are locked remote will not unlock the car. Once i manually unlock...
it is not the actuators, try a different remote, you may have an issue with the car security system/body computer not functioning on the unlock driver door command, one press of remote is unlock driver door and 2 presses is unlock the other doors.
Top Grundig Televison & Video Experts
Jean Thiebaux
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Grundig Televison and Video Expert? Answer questions, earn points and help others
