Re: how do i get my lg32lx4dc tv out of hotel mode?
You have to enter its service mode option to release the Hotel mode. For that, you should have its 'Service Remote Control'; not the user remote control. It will be best to contact the authorized service center for LG. google.com/+GopakumarGopalan
To turn off the hotel mode on an Onida Ultra Slim TV, you need to follow these steps:
Turn on the TV and press the "Menu" button on the remote control.
Use the navigation buttons to select the "Setup" option and press the "OK" button.
Navigate to the "Installation" option and select it.
Select the "Hotel Mode" option and change the setting to "Off".
Use the remote control to enter the password. The default password is usually "0000" or "1234". If these do not work, please refer to the manual for your TV model for the correct password.
Once the correct password is entered, the hotel mode will be turned off.
Save the changes and exit the menu by pressing the "Menu" button.
After completing these steps, the hotel mode should be turned off and you should be able to use all the features of the TV as normal. If you encounter any issues or if the steps do not work for your TV model, please refer to the manual or contact Onida customer support for assistance.
Getting out of the hotel mode is very easy. Just go get the Panasonic remote and open your tv. Go near the tv and hold down the V/- button on the television itself. Then use the remote and press the AV button for 3 times. A hidden menu on the television screen will appear. Turn off the "Hotel Mode" from the menu and exit. Do not touch anything from the hidden menu except the hotel mode. Now you can use your tv in normal mode. The remote is required to access the hidden menu so be sure your remote is working and has working or full charged battery before doing the steps above
This is for Panasonic but might help you
Getting out of the hotel mode is very easy. Just go get the Panasonic remote and open your tv. Go near the tv and hold down the AV/- button on the television itself. Then use the remote and press the AV button for 3 times. A hidden menu on the television screen will appear. Turn off the "Hotel Mode" from the menu and exit. Do not touch anything from the hidden menu except the hotel mode. Now you can use your tv in normal mode. The remote is required to access the hidden menu so be sure your remote is working and has working or full charged battery before doing the steps above.
For Toshiba model 32AV635D, press mute once press mute again and hold, at the same time press "P Up" on the TV side panel and you enter direct to the menu to change the hotel mode back to home mode
sorry, it wont go away, bet ya got it cheap huh(nothing intended by cheap) but the tv hotel mode is telling you that its a special tuner made for just hotels, the only way to get around this is if you can replace the hotel type tuner on the main-board with a normal type tuner, it'll cost more than you paid though.good luck,a friend of mine bought 12 of then at $25 each, boy he thought what a deal, now he's really crying and they didn't tell him,and they won't refund his money
M (menu) 7935 (regular menu appears), them press
4725 (menu service appears), then search HTLSRC (position 090), then
set value 032 (this value disables Hotel Mode) - TV. Now Hotel Mode is
deactivated. It is verified!
M 7935 4725, go to HTLSRC (090), fix 032 - press TV. Good luck!
