Cars & Trucks Logo
Michael Rapuano Posted on Jun 08, 2015
ON a Teknique GT rear wheel drive, I have a low front tire and valve stem is too short to hook up air hose, there is no room to attach air hose. What can I do?
The valve stem is short and angled so you cannot attach an air hose to it. Very poor design
James Spradley
Level 1:
Habit-Forming:
New Friend:
  • Contributor 9 Answers
  • Posted on Jun 08, 2015
James Spradley
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
9
Questions
Helped
2387
Points
22
Most parts stores have extensions that may solve the problem. tractor/trailer parts store would also be a place to look.
How do I reset the low tire indicator on a 2015 F350 truck. All tire pressures are at 70 pounds
Just drive it. Sometimes it just takes a little time for the system to update
Proportioning valve 1988 f350
The reason is, you have a rear anti lock brake system. The anti lock valve is located on the frame just underneath the brake master. It is called a RABS valve. Almost impossible to bleed. But it can be done. A dealer has a tool that plugs into the RABS valve which activates the valve constantly moving the valve back and forth. This will then push all fluid and air out of your open bleeder screws in the rear.
I did'nt go to the dealer. i was too stubborn. My solution was to lift the rear of the truck and place on jack stands. Pinch off the rubber brake hoses on the 2 front brakes with a C-clamp or non marring vise grips, this will keep all fluid from going to front brakes. Next adjust the rear brake shoes by tightening the adjuster on the rear brake drums. Tighten the brakes on the rear until the brakes start to drag and the tires no longer spin freely by hand. Attach a bleeder hose to the bleeder screw on the RABS valve, place open end of hose into a jar or canister of brake fluid, so as not to draw in any air. Open the bleeder screw. Start the vehicle up, put it in gear, and let the rear tires spin. (I got up to 25mph on my speedometer) Step on the brake while it is in gear and the tires are spinning. This will activate the RABS valve and cause the air in the RABS valve to bleed. Do this several times. Put vehicle in park, shut off engine, and close the bleeder on the RABS valve. Attach bleeder hose to right rear of the truck, place open end of hose in a canister or jar of brake fluid so no air gets in and open the bleeder screw. Start the vehicle up, put it in gear, and let the rear wheels spin freely. As the wheels spin, you press your foot on the brake pedal, this will activate the RABS valve, and effectively bleed the brakes. Do this a dozen or so times, tighten the bleeder screw and do the other side. Remove clamps from front brake hoses and you will be go to go. All this may seem a bit extreme, but it is the only effective way to bleed a Rear Anti Lock Brake System on an early Ford. All the steps I laid out are necessary. You cannot skip one. The reason why the rear has to be in the air, is that there is a sensor mounted to the rear differential that senses wheel spin(or axle spin), this goes directly to the RABS valve and tells it that the tires are moving at a certain speed, and to activate the Rear Anti Lock Brakes when the brake pedal is depressed. It will not activate if it does not sense movement. The reason for pinching off the front brake lines, is that there are needle valves in the master cylinder and they will send too much fluid to the front calipers, and stifle or hinder the amount of fluid needed to go to the rabs valve and ultimately the rear wheel cylinders. It seems like a lot, and it is, but I did it and it works. Good luck
3helpful
2answers
My front wheel sensor shows low tire pressure, but it is fine. Is there a reset for that?
If its reading low and the tire pressure is correct there is a problem with that sensor. Typically they need to be replaced in order to correct the problem. A TPMS tool capable of displaying TPMS sensor data would confirm the bad reading.
They display the tire pressure as a convenience. They don't have to display the pressures and many makes/models do not.
The level of sophistication with these systems is slowly improving. Many newer models will automatically know where the tire is and display it correctly. Unfortunately yours need to be relearned manually after every tire rotation which is very common with earlier systems. It is assumed that this is done after every tire rotation which would then make the displayed tire locations correct.
If you are confident that the correct tire location is being displayed than I wouldn't see any issue with replacing that sensor. If you are not confident the correct tire location is being displayed than it wouldn't be a bad idea to do a relearn procedure.
The TPMS matching process is outlined below:
1. Set the parking brake.
2. Turn the ignition switch to ON/RUN with the
engine off.
3. Press and hold the Remote Keyless Entry (RKE)
transmitter's LOCK and UNLOCK buttons, at the
same time, for about five seconds to start the TPMS
learn mode. The horn sounds twice indicating the
TPMS receiver is ready and in learn mode.
4. Start with the driver side front tire. The driver side
front turn signal also comes on to indicate that
corner's sensor is ready to be learned.
5. Remove the valve cap from the tire's valve
stem. Activate the TPMS sensor by increasing
or decreasing the tire's air pressure for about
eight seconds. The horn chirp, can take up to
30 seconds to sound. It chirps one time and then
all the turn signals flash one time to confirm the
sensor identification code has been matched to
the tire/wheel position.
6. The passenger side front turn signal comes on to
indicate that corner sensor is ready to be learned.
Proceed to the passenger side front tire and
repeat the procedure in Step 5.
7. The passenger side rear turn signal comes on to
Proceed to the passenger side rear tire and
8. The driver side rear turn signal comes on to
Proceed to the driver side rear tire, and repeat
9. After hearing the single horn chirp for the driver
side rear tire, two additional horn chirps sound
to indicate the tire learning process is done.
Turn the ignition switch to LOCK/OFF.
If no tires are learned after entering the TPMS learn
mode, or if communication with the receiver stops, or
if the time limit has expired, turn the ignition switch to
LOCK/OFF and start over beginning with Step 2.
10. Set all four tires to the recommended air pressure
level as indicated on the Tire and Loading
Information label.
11. Put the valve caps back on the valve stems.
This info can also be found on page 5-66 of your owners manual.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
2helpful
Service tire monitor on what is the problem? how do you reset the system?
TIRE PRESSURE MONITOR SYSTEM
The Tire Pressure Monitor System (TPMS) uses radio and sensor technology to check tire pressure levels. If your vehicle has this feature, sensors are mounted on each tire and wheel assembly, except the spare tire. The TPMS sensors monitor the air pressure in your vehicle's tires and transmit tire pressure readings to a receiver located in the vehicle.
The TPMS is designed to alert the driver, if a low tire pressure condition exists. This system also allows the driver to check tire pressure levels using the Driver Information Center (DIC).
When a low tire pressure condition is detected, the TPMS displays the "CHECK TIRE PRESSURE" warning message on the DIC, and at the same time illuminates the low tire pressure warning symbol.
You may notice, during cooler weather conditions, that the tire pressure monitor light, located on the instrument panel cluster, and the "CHECK TIRE PRESSURE" message will appear when the vehicle is first started and then turn off as you start to drive the vehicle. This could be an early indicator that the tire pressures are getting low and need to be inflated to the proper pressure.
Each tire, including the spare (if provided), should be checked monthly when cold and inflated to the inflation pressure recommended by the vehicle manufacturer on the vehicle placard or tire inflation pressure label. (If your vehicle has tires of a different size than the size indicated on the vehicle placard or tire inflation pressure label, you should determine the proper inflation pressure for those tires.)
As an added safety feature, your vehicle has been equipped with a tire pressure monitoring system (TPMS) that illuminates a low tire pressure telltale when one or more of your tires is significantly under-inflated.
Accordingly, when the low tire pressure telltale illuminates, you should stop and check your tires as soon as possible, and inflate them to the proper pressure. Driving on a significantly under-inflated tire causes the tire to overheat and can lead to tire failure. Under-inflation also reduces fuel efficiency and tire tread life, and may affect the vehicle's handling and stopping ability.
Please note that the TPMS is not a substitute for proper tire maintenance, and it is the driver's responsibility to maintain correct tire pressure, even if under-inflation has not reached the level to trigger illumination of the TPMS low tire pressure telltale.
The "CHECK TIRE PRESSURE" warning message and low tire pressure light (telltale) will appear at each ignition cycle until the tires are inflated to the correct inflation pressure.
The Tire and Loading Information label (tire information placard) shows the size of your vehicle's original tires and the correct inflation pressure for your vehicle's tires when they are cold.
Your vehicle's TPMS can alert you about a low tire pressure condition but it does not replace normal tire maintenance.
NOTICE: Do not use a tire sealant if your vehicle has Tire Pressure Monitors. The liquid sealant can damage the tire pressure monitor sensors.
RESETTING THE TPMS IDENTIFICATION CODES
Each TPMS sensor has a unique identification code. Any time you rotate your vehicle's tires or replace one or more of the TPMS sensors, the identification codes will need to be matched to the new tire/wheel position. Each tire/wheel position is matched to a sensor, by increasing or decreasing the tire's air pressure. The sensors are matched to the tire/wheel positions in the following order: LF TIRE (left front tire on the driver's side of the vehicle), RF TIRE (right front tire on the passengers side of the vehicle), RR TIRE (right rear tire on the passengers side of the vehicle), and LR TIRE (left rear tire on the driver's side of the vehicle).
You will have one minute to match the first tire/wheel position, and five minutes overall to match all four tire/wheel positions. If it takes longer than one minute, to match the first tire and wheel, or more than five minutes to match all four tire and wheel positions the matching process stops and you will need to start over.
The TPMS sensor matching process is outlined below:
  2. Turn the ignition switch to "RUN" with the engine off.
  3. Turn the headlamp switch from "OFF" to the parking lamps setting four times within three seconds. A double horn chirp will sound and the TPMS low tire warning light will begin to flash. The double horn chirp and flashing TPMS warning light indicate that the TPMS matching process has started. The TPMS warning light should continue flashing throughout the matching procedure. The "SERVICE TIRE MONITOR" message will be displayed on the Driver Information Center (DIC).
  4. Start with the driver's side front tire.
  5. Remove the valve cap from the valve cap stem. Activate the TPMS sensor by increasing or decreasing the tire's air pressure for 10 seconds, then stop and listen for a single horn chirp. The single horn chirp should sound within 15 seconds, confirming that the sensor identification code has been matched to this tire and wheel position. If you do not hear the confirming single horn chirp, you will need to start over with Step 1. To let air-pressure out of a tire you can use the pointed end of the valve cap, a pencil-style air pressure gage or a key.
  6. Proceed to the passenger's side front tire, and repeat the procedure in Step 5.
  7. Proceed to the passenger's side rear tire, and repeat the procedure in Step 5.
  8. Proceed to the driver's side rear tire, and repeat the procedure in Step 5.
  9. After hearing the confirming horn chirp for the left rear tire, check to see if the TPMS warning light is still flashing. If it is, turn the ignition switch to LOCK to exit the sensor matching process. If the TPMS warning light is not flashing, the five minute time limit has passed and you will need to start the process over beginning with Step 1.
  10. Set all four tires to the recommended air pressure level as indicated on the Tire and Loading Information label.
  11. Put the valve caps back on the valve stems. The spare tire does not have a TPMS sensor. If you replace one of the road tires with the spare, the "CHECK TIRE PRESSURE" message will be displayed on the DIC screen. This message should go off once you re-install the road tire containing the TPMS sensor. The "SERVICE TIRE MONITOR" message is displayed when the TPMS is malfunctioning. One or more missing or inoperable TPMS sensors will cause the service tire monitor message to be displayed.
The level light for rear tires comes on, have to stop & fill the back tires with air every hour or so while driving. What could be causing this?
Have them both checked for leaks. May be a valve stem or corroded wheel, but the only way to know is to have them checked.
One good idea is to spray soapy water from a spray bottle all over the tire, rim area, and around the valve with the cap off. Flex the valve stem as they can crack and leak air.
Front tire are constantly loosing air. got new
ck the wheels, valve stems, sealing beads?
17helpful
3answers
How do i reset the tpms on a 08 implala SS after a tire rotation,without a owners manual
You have two minutes to match the first tire/wheel position, and five minutes overall to match all four tire/wheel positions. If it takes longer than two minutes, to match the first tire and wheel, or more than five minutes to match all four tire and wheel positions the matching process stops and you need to start over.
  2. Turn the ignition switch to ON/RUN with the engine off.
  3. Press the Remote Keyless Entry (RKE) transmitter's lock and unlock buttons at the same time for approximately five seconds. The horn sounds twice to signal the receiver is in relearn mode and TIRE LEARNING ACTIVE message displays on the DIC screen.
  5. Remove the valve cap from the valve cap stem. Activate the TPMS sensor by increasing or decreasing the tire's air pressure for five seconds, or until a horn chirp sounds. The horn chirp, which may take up to 30 seconds to sound, confirms that the sensor identification code has been matched to this tire and wheel position.
  6. Proceed to the passenger side front tire, and repeat the procedure in Step 5.
  7. Proceed to the passenger side rear tire, and repeat the procedure in Step 5.
  8. Proceed to the driver side rear tire, and repeat the procedure in Step 5. The horn sounds two times to indicate the sensor identification code has been matched to the driver side rear tire, and the TPMS sensor matching process is no longer active. The TIRE LEARNING ACTIVE message on the DIC display screen goes off.
  9. Turn the ignition switch to LOCK/OFF.
12helpful
2answers
How to reset the tire pressure on a 08' chevy tahoe?
TPMS Sensor Matching Procedure
Each TPMS sensor has a unique identification code. Any time you rotate your vehicle's tires or replace one or more of the TPMS sensors, the identification codes will need to be matched to the new tire/wheel position. The sensors are matched to the tire/wheel positions in the following order: driver side front tire, passenger side front tire, passenger side rear tire, and driver side rear tire using a TPMS diagnostic tool. See your dealer/retailer for service.
The TPMS sensors can also be matched to each tire/wheel position by increasing or decreasing the tire's air pressure. If increasing the tire's air pressure, do not exceed the maximum inflation pressure indicated on the tire's sidewall.
To decrease air-pressure out of a tire you can use the pointed end of the valve cap, a pencil-style air pressure gage, or a key.
  3. Press the Remote Keyless Entry (RKE) transmitter's LOCK and UNLOCK buttons at the same time for approximately five seconds. The horn sounds twice to signal the receiver is in relearn mode and TIRE LEARNING ACTIVE message displays on the DIC screen.
2helpful
3answers
Where do I hook the R-134 freon up to charge the system? I can't find the valve to hook up the freon, where is it located
Follow the large tube/hose coming out of the dash to a large aluminum canister that then has a hose or tube that goes to the compressor. It is probably located on the side of that canister (the accumulator) under a little blue screw on cap.. WEAR EYE PROTECTION AND GLOVES WHILE HANDLING REFRIGERANT!
6helpful
4answers
2003 Cadillac seville sts TPMS reset
From 2005 STS Owners manual:
Each TPM sensor has a unique identification code. Any
time you replace one or more of the TPM sensors,
matched, to a sensor, by increasing or decreasing the
tire’s air pressure. The sensors are matched, to the
tire/wheel positions, in the following order: left front (LF),
right front (RF), right rear (RR), and left rear (LR).
position, and five minutes overall, to match all four
minutes to match all four tire/wheel positions the
The TPM matching process is outlined below:
2. Press the push-button ignition switch to OFF/ACC.
3. Using the Keyless Access transmitter, lock and
unlock the vehicle’s doors.
4. Press the lock and unlock buttons, at the same
time, on the Keyless Access transmitter. A single
horn chirp will sound, indicating that the TPM
system is ready, and the sensor matching process
can begin.
5. Start with the left (driver’s side) front tire.
6. Remove the valve cap from the valve stem.
Activate the TPM sensor by increasing or
decreasing the tire’s air pressure for five seconds,
which may take up to 30 seconds, confirms that the
this tire position. To decrease the tire’s air-pressure
use the pointy end of the valve cap, a pencil-style
7. Proceed to the right (passenger’s side) front tire,
and repeat the procedure in Step 6.
8. Proceed to the right (passenger’s side) rear tire,
9. Proceed to the left (driver’s side) rear tire, and
10. After hearing the confirming double horn chirp, for
the left rear tire, exit the matching process by
turning the ignition switch to OFF/ACC.
11. Set all four tires to the recommended air
pressure level as indicated on the tire and loading
information label.
12. Put the valve caps back on the valve stems.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
