Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
Vivian Vallone Posted on Jun 07, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Any other reason besides a faulty spring tensioner why my belt would keep coming off?
I put a new belt on and it came off with in a minute off driving it.
terry stevens
Level 3:
  • Master 991 Answers
  • Posted on Jun 07, 2015
terry stevens
Master
Level 3:
Answers
991
Questions
0
Helped
196840
Points
8536
Bad pulley bearings or twisted cutter deck
1helpful
I have replaced the drive belt on my delta 34-670 and the teeth on the rubber belt 100XL keeps stripping under the least amount of load. the drive belt keeps stripping on my delta 34-670
several possible reasons
build up of worn belt in the teeth of the gears
incorrect belt being used (wrong pitch belt being used -not genuine)
shafts being driven are not free to turn--seizing on the bearings, incorrect placement of rocker shafts /pushrods---valve springs bottoming out locking the shaft
incorrect tensioner actioner ( hydraulic tensioner not tensioning properly allowing the belt to flap in operation)
idler pulley problems ( bearings or misalignment of all pulleys
I have a iszuzu wizard or rodeo. I have changed the battery and the alternator. The new battery still drain down. The alternator is also putting out low voltage, 12.9.
have the regulator checked as the required voltage is 14.5-14.8 volts dc
check for drive belt condition and tension
with a voltage of 12 volts and insufficient charge the battery will drain down as more is going out than being provided by the alternator
besides that if the regulator is faulty it may be a reason for draining the battery
1helpful
2answers
Install a belt tensioner in 2004 freestar
2004 Ford Freestar:
Accessory belt drive removal and installation:
    1.Put the vehicle in neutral, and put it on hoist.
    2.Rotate the accessory drive belt tensioner counterclockwise.
    3.Push the spring clip towards the belt tensioner to lock the accessory drive belt tensioner in place and remove the belt.
    4.To install the accessory drive belt, on the engine, rotate the accessory drive belt tensioner counterclockwise till the spring clip releases.
    5.Install the belt.
Why does serpentine belt keep coming off
The three most common reasons are - the belt is stretched and the tensioner can not keep it tight - the tensioner spring is damaged and its not keeping the belt tight - or one of the pulleys is not aligned with the others.
How to adjust a belt on a 17.5 ryobi 42 in riding mower belt is loose just keep spining i have to **** the mower foward to move it sometime it takes but most of the time all it does is spin he polley and...
drop the deck and take a long look at the drive belt. somewhere along its path you will see a spring loaded arm with a pulley on the end. that arm is the tensioner, if it is not keeping adequate tension on the transmission end of the belt then either you are using the wrong belt, the spring has been taken off and put back on wrong, or the spring has just lost its springiness. You are going to have to figure out which problem and remedy it. Mower parts are common and are sold at small engine repair shops which you can find in the phone book or with a google search.
one other possibility is that someone has removed the drive belt and put it on incorrectly. there are generally guides close in around the front pulley to keep the belt from jumping off, and it has happened before that someone has unknowingly put a new belt on over instead of under the guide. you have to look close to see this.
1helpful
Replaced a drive belt on a 2001 chevey malibu and the belt keep walking off. I appears that the pullys are now not in allignment.
If your belt kept slipping off I would check your tensioner pulley. It is possible that the spring mechanism inside of it has broke and the belt is not getting tight enough. That could also be the reason the pulleys look misaligned. I have seen worn out tensioners that sit funny just because they are worn out. Take the belt off and check all of your pulleys make sure the bearings all spin fine and put your wrench on the tensioner and move it, see if it springs back.
Replace serpentine belt
Removal & Installation
  1. Rotate the drive belt tensioner clockwise and remove the drive belt.
    WARNING Never suddenly let go of the tensioned idler pulley. The force of the spring pressure suddenly released may damage the idler pulley mechanism. Always release the spring pressure gradually.
    Fig. Rotate the belt tensioner to relieve tension on the belt-4.6L engine shown, others similar
To install:
  1. Route the belt over the pulleys making sure all the grooves in the pulleys and the belt line up correctly. Refer to the accessory belt routing section of this manual.
  2. Rotate belt tensioner clockwise and slip drive belt over idler pulley on tensioner.
To install:
  1. Route the belt over the pulleys making sure all the grooves in the pulleys and the belt line up correctly. Refer to the accessory belt routing diagrams above.
If for any reason, the tensioner is crooked, replace it!!! Also, install the belt with the writing facing you like you are trying to read a book. This WILL (a trick I learned at Mercedes) prevent even a new belt from squeeling!!
Belt problem
If the belt has got oil soaked into it could be one reason why it is coming off. Check the belt tensioner. The spring may have become weak or the tensioner bearing is bad and the pulley is wobbling.
2helpful
What tools do I need to remove both engine belts from my wife's 2004 Concorde.do I need ome special tensioner tool to move the tensioner the other belt is a regular v belt and it goes around the...
2.7L & 3.5L Engines same Tools & Procedure Rate Me Please 1/2 in. breaker bar & Special Tool 7198 for conventional V-belts and Poly-V belts
  1. REMOVAL
    AIR CONDITIONING BELT
    NOTE: The A/C drive belt self tensioner is NOT a dynamic tensioner. After adjustment the tensioner bracket bolts are tightened. The torsion spring is no longer responsible for tensioning the A/C belt. The torsion spring is only used for initial belt tensioning.
    1. Remove generator/power steering belt to gain access to A/C belt. Refer to GENERATOR/POWER STEERING BELT for procedure.
    1. Loosen BUT DO NOT REMOVE tensioner locking bolt and pivot bolt (Fig. 2).
    2. Insert 1/2" drive breaker bar into square opening on belt tensioner. Rotate tensioner counterclockwise until belt can be removed from pulleys (Fig. 2).
    3. Slowly rotate tensioner clockwise to relieve spring load.
    CLEANING
    Clean all foreign debris from belt pulley grooves. The belt pulleys must be free of oil, grease, and coolants before installing the drive belt.
    INSPECTION
    Belt replacement under any or all of the following conditions is required:
    • Excessive wear
    • Frayed cords
    • Severe glazing
  • Poly-V Belt system may develop minor cracks across the ribbed side (due to reverse bending). These minor cracks are considered normal and acceptable. Parallel cracks are not (Fig. 3).
    NOTE:
    Do not use any type of belt dressing or restorer on Poly-V Belts. INSTALLATION
    AIR CONDITIONING BELT - NEW
    WARNING: DO NOT REMOVE A/C BELT TENSIONER LOCKING BOLT WITHOUT FIRST HOLDING THE TENSIONER WITH A 1/2" DRIVE BREAKER BAR, AS PERSONAL INJURY COULD RESULT.
NOTE: Verify that torsion spring position is in the new belt position before installing a NEW belt (Fig. 4). If torsion spring is not in the new belt position, follow steps 1-7 to change the tensioner spring from the USED belt position to the NEW belt position.
  1. Insert a 1/2" drive breaker bar into the square opening on the tensioner. Hold counterclockwise pressure on tensioner while removing the locking bolt (Fig. 2).
  2. Carefully release spring load of the torsion spring on the tensioner.
  3. Remove pivot bolt, tensioner, and spring from front timing cover.
  4. Insert spring arm into the NEW belt position on the tensioner (Fig. 4).
  5. Install torsion spring, tensioner, and pivot bolt.
  6. Install pivot bolt. Tighten only finger tight, at this time.
  7. Using a 1/2" drive breaker bar, apply counterclockwise pressure until locking bolt can be installed.
    1. Install the NEW belt by rotating the tensioner counterclockwise until the NEW belt can be installed on pulleys. See (Fig. 5) for belt routing.
    2. Release tensioner and remove breaker bar. Belt is automatically adjusted with the tensioner's torsion spring.
    3. Tighten tensioner locking bolt and pivot bolt to 28 Nm (250 in. lbs.) (Fig. 2).
    4. Install generator/power steering belt.
    AIR CONDITIONING BELT - USED
    NOTE: A "used belt" is considered having more than 500 miles of service use. NOTE: Perform steps 1-7 to change the tensioner spring from the NEW belt position, to the USED belt position.
    1. Insert a 1/2" drive breaker bar into the square opening on tensioner. Hold counterclockwise pressure on tensioner, while removing tensioner locking bolt (Fig. 2).
    2. Carefully release the tension of spring on tensioner.
    3. Remove pivot bolt, tensioner, and spring from front cover.
    4. Insert spring into the USED belt position on tensioner bracket (Fig. 4).
    5. Install spring, tensioner bracket, and pivot bolt.
    8. Install the USED belt by rotating tensioner counterclockwise until belt can be installed on pulleys. See (Fig. 5) for belt routing.
    9. Release tensioner and remove breaker bar. Belt is automatically adjusted with the tensioner's torsion spring.
    10. Tighten tensioner locking bolt and pivot bolt to 28 Nm (250 in. lbs.) (Fig. 2).
    11. Install generator/power steering belt.
I Hope This is Of Help To YOU IF So PLEASE HELP ME RATE ME it Helps Thank You Very Much and Happy Motoring !!!!!!!!
2helpful
3answers
The belt keeps coming off the fan
the only reason for the belt coming off the pulley is the something in the belt path is off aligment.
put the belt back on and chek the path where the belt pass. water pump, alternator, AC compressor, Power steeling unit, etc....... or even the pulley tensioner itself.
chance are there is a belt in the wrong pully slot.
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
