Jammed and broke needle. Turned off & unplugged to reset machine. Step on peddle it beeps. Can still fill new bobbins. Unable to sew.
Try rethreading the machine--use EVERY thread guide
make sure the needle is inserted up into the needle holder and turned the right direction
make sure the bobbin is inserted correctly into the bobbin case and turned the right direction
clean under the needle plate and in the bobbin area for loose thread or lint
make sure thread has not come off the thread take up lever
also the jam could have caused the machine to jump time and needs a timing or a adjustment
Thank you for your input. I re-cleaned the entire machine even using dental floss through the upper thread. took off the left plastic piece and cleaned. lubricated moving parts. checked the feed and button hole lever. Put it back together and it worked!
