Computers & Internet Logo
l
levette Posted on Jun 06, 2015
Sony hbd-n790w is stuck on welcome - Sony Computers & Internet
2answers
Sony Hbd tz510 remote code
The remote control code for Sony HBD-TZ510 home theater system may vary depending on the brand of the remote you are using. Here are a few common remote control codes that may work:
  • 30158
  • 31759
  • 31939
  • 31758
To program your remote, follow these steps:
  1. Turn on your Sony HBD-TZ510 home theater system.
  2. Press and hold the "Code Search" button on your remote control until the indicator light illuminates.
  3. Press the "DVD" or "AUX" button on your remote to select the device you want to program.
  4. Enter the four-digit code using the number buttons on your remote.
  5. Press the "Power" button to test if the code is correct. The device should turn off if the code is correct.
  6. If the device turns off, press the "Enter" button to save the code. The indicator light will turn off.
  7. If the device does not turn off, repeat steps 4-6 with a different code until you find the correct one.
Note: If you do not have the original remote control that came with your Sony HBD-TZ510, you may need to purchase a universal remote control that is compatible with your device.
Sony dvd hbd-dz640k is ded
Most of SMPS can be repaired by local technicians, if u have a local person available, get it repaired, else submit at service center & get it repaired done.
Sony hbd-e570 When playing DVD no color
Make sure the TV and Sony are the same format. Either PAL or NTSC depending on what country you are in. You cannot mix formats.
1helpful
Free region for Sony dvd hbd-e570 (3d)
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Region code hack procedure to many brand DVDs are given.
Why is my Sony bdvn790 stuck on bd/DVD and the front light flashes
I am having the same issue. From what I can tell (at least in my case), there was a disc stuck in the DVD drive. I had to dismantle the chassis, remove the drive and manually "eject" the disc. There is a manual screw port under the BD/DVD drive that you turn and it will manually eject the disc. However, removing the disc from the drive did not solve my problem. I am still getting the BD/DVD displayed when powering the system back on and the light is flashing as you described.
"RM OFF"
I am having the same problem - did you find a way to fix this???
MY SONY HBD-DZ810 HOME THEATER IS CONSTANTLY SHOWING PUSH POWER PROTECTOR
The "PROTECT" and "PUSH POWER" messages will flash alternately when the protective device of the amplifier has been activated because a strong signal was input, or if there is a short-circuit detected. Press the POWER button on the unit to turn off the system, and check the following items after "STANDBY" disappears.
1) Are the + and - speaker cords short-circuited?
2) Are you using only the specified speakers?.
3) Is anything blocking the ventilation holes of the system?
You may also refer to the following link for additional troubleshooting steps.
PROTECT and PUSH POWER flash alternately on the amplifier screen
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
