Hold the SD card so that the contacts are on the underside and the clipped corner is at the top right.
On the left hand edge of the card is a lock switch, forward (towards the contacts) is unlocked. If it's in the locked position then slide it fully to unlocked (usually a small click when unlocked). If already in the unlocked position, slide it fully to locked and then fully back to unlocked.
If this fails, the card is a dud and needs to be exchanged.
Take the memory card out of the camera and look at it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Take the memory card out of the camera and look at it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again. Then put the card back into the camera.
Your memory card has a sliding switch along one edge. It is unlocked when it is nearest to the electrical contacts and locked when it is furthest from them. If it is locked then just slide it firmly to the unlocked position. If it appears to be in the unlocked position then slide it fully to the locked position and then fully back to the unlocked position.
If this does not work then try another memory card.
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Your question does not display properly, but I'll assume that the error message is telling you that your memory card is locked and cannot be written to.
Make sure that the camera is turned off and then remove the SD memory card from the camera.
Look at the card carefully, and you'll see a small switch used to lock the card to protect the data from being deleted/overwritten. Slide it fully to the unlocked position; if it's already there then slide it fully to locked and then fully to unlocked.
If this doesn't work then remove the card again and use a CLEAN pencil eraser on the electrical contacts to clean them. Do not use a dirty eraser as the graphite on the eraser is electrically conductive and can ruin your SD card. Also do not use an ink eraser as they're very abrasive and usually have conductive metal particles in them.
If this still does not work then you need to buy or borrow another SD card and make sure that it's switch is fully unlocked. If it works then you have a faulty SD card and must replace it with a new one, if not then you have a camera fault and this is beyond the scope of any DIY/FixYa repair.
I hope that my posting has assisted you and in return I ask only that you please take a moment to rate my answer.
