You have to enter its service mode option to set its language. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Hi ,
Check problem is in AV mode only or both AV and RF
If both mode problem is there follow the bellow
Other wise problem May RCA cable (AV cable)
I f you are able to open TV check speaker using a Multimeter (Tv should be OFF) continuity mode,is it shows 2 ohms or below speaker is ok, problem may be audio section of your TV.
To reset it to factory settings, you have to enter its service mode option. If you wish to get more details about how to enter, adjust and exit service mode, check this site. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the
brand name and model number to of your set, to its search box, and press 'Enter'
or view it in Mosaic / Timeslide option.
Just make sure they are stk392-110 I have the same tv and I just replaced them, I used generic chips and I have the same tv, also check on that board for burnt resistors alot of the time they go bad, there with be burn marks or or small cracks in them
for this jvc model tv
