F1 - E0
EEPROM communication error
1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Note: Applies to all F1-E... codes except F1-E3.
F1 - E1
EEPROM checksum error
F1 - E2
UL A/D error(s)
F1 - E4
Model ID error
F1 - E5
Calibration shifted
F1 - E6
Latch signal mismatch error
F1 - E9
Stack overflow
F1 - E3
Wiring harness cavity size does not match previously stored value
The "Cavity Size Select" jumpers in the wiring harness indicate a cavity size different from that which the control was previously configured for. Check the jumpers in the harness to make sure they agree with the actual oven size.
Good Morning friend, thank you for your post!
Based off the information you have provided your Frigidaire oven, PLEF398DCH, has locked you out and you are unable to fix it. Sometimes a reset can fix this problem. In order to reset your oven you would need to flip the household circuit breaker off for roughly ten minutes.
If this does not help correct the issue you can perform a self-clean and right before the clean starts press the cancel or clear button. This should trick the oven into disengaging your door lock. Lastly, hold down the clear or cancel button for 10 to 15 seconds and that should release the lock. If you perform all this troubleshooting and the door is still locked it could be a bad latch and that may need to be replaced. I hope this information is helpful. -Matt
STOP SPAM!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
