Read through link below
http://www.doityourself.com/forum/electrical-power-machinery-hand-power-tools-sharpening/359951-puddles-oil-my-air-compressor-tank.html
SOURCE: Compressor spewing Oil
hi your machine will discharge oil from the vent if your rings or bores are worn ,if the oil comes out with the air the your valves are broken or not sealing
hope this helps
ian
SOURCE: craftsman 1 gallon direct drive oil filled wont build air pressure
It sounds like you may have a broken reed on the diaphragm plate. This is located at the block. Remove the cover, and look for a cast metal assembly with fins. It will be attached to the side.
SOURCE: Compressor turns on but no air in tank. Oil level
Dismentl the valve plate check the gaskets and the valves,cif not good change and it wlii be ok
SOURCE: should air compressor tanks be drained daily
No additional moisture will accumulate over time. Some existing moisture may condense as the unit cools down, though. If you drain off the water at the end of the day, I see no good reason to completely drain the air.
Testimonial: "Thank you for your quick response,your information is useful and informative. Thanks"
