Belt comes off the motor pulley.
There are no belt adjusters on most mowers, they gave spring loaded constant adjusters..if the belt is coming off it because the belt is worn..your mower should have one or two adjustable belt protectors around the the motor and deck pulleys they keep the belt from coming off during on and off operations the design is to be set close enough to the pulleys that will not allow the thickness of the belt to pass through...so if the belt is Worn too much or the proctectors are out of adjustment the belt will come off..usually during non mowing or just when engaging the deck or drive..kind of tricky to get at..but can be done yourself...do check them out if they are more then about 1/4-3/8 inch they are out if adjustment..if not the belt is worn out...good luck..
