I have a 2005 or so Frigidaire gallery wall convection oven (FEB386WECH) and it broils but the bake element will not get hot. When on bake, it get's to 200-245 deg. OHM test showed bake element ok (19)
If bake element is not getting red hot, either the element is bad or the relay on the control is bad.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jeffrey_634abadf963e31e5
Thermostat is bad
Hello kimberlymaso - If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works; contact a professional to diagnose the EOC (electronic oven control).
If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works, contact a professional to have the EOC (electronic oven control) diagnosed.
