Lyle, your particular model is designed for the fan to function constantly. However, the fan running doesn't mean the compressor is always running. The reason the unit was designed this way, is for the air to be continually moving, and when the humidity sensor picks up a rise in the humidity level (above where you have it set) the compressor will turn ON and extract that humidity.
Your unit is working as it should. Thanks for choosing FixYa.
The fan has to run or the moisture will freeze on the coil, try to help the fan motor turn reach in and the blade a flick in any direction and then pull your long skinny helper out and watch the fan it may just run or give you a idea whats up. They get dirty and I'm sure that it worked last time. Nothing fancy but it might help.
It sounds like what you hear working is the fan. The unit also has a compressor; if the compressor is bad or the freon is gone, the fan will run but the coils wont cool to remove moisture from the air.
No, there is no fuse or circuit breaker to reset on your unit. However, there are several things r=than can cause the problem, you're experiencing:
The unit's humidity level may be set to high. Lower it to 35%
The air intake filter may be dirty or clogged. Remove the filter and clean it
The compressor coils may need cleaning.
The air ambient air temperature may be to low. Dehumidifiers don't function well between 40 & 60 degrees F.
The unit may need to reset itself. Turn the Master ON/OFF Switch to OFF and unplug the unit for 12-15 minutes. Plug it back in and turn the Master ON/OFF Switch to ON. Set the humidity level to 35%. Allow the unit to operate in Automatic Timed Mode, rather than continuous mode.
Make sure there is at least a minimum of 12" of clear air space around the entire unit, when in operation.
If none of the above solves the problem, the humidity sensor may have failed. In which case it should be replaced. Or the compressor needs to be recharged with refrigerant.
I hope this helps you troubleshoot and solve the problem.
No, no switch or fuse...bad board or fan motor...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Part of the problem may be that you have the humidity level set to high. The fan runs constantly to move the air around. When the unit senses a humidity level higher than what you have it set for, the compressor turns ON. Once it's ON, if the humidity level is short lived, it turns OFF.
Try setting the humidity level to the lowest possible setting. Usually, that 45%. If the humidity level in you home is higher than that, the compressor should turn ON and run until either the bucket is full or the humidity level reaches 45%. If this doesn't solve the problem, turn the Master ON/OFF Switch to OFF and unplug the unit from the wall outlet for 12-15 minutes. Plug the unit bakc in, turn the Master ON/OFF Switch to ON and set the humidity level at it's lowest setting. Allow the unit to run until it cuts OFF and check the bucket for water. Hopefully that 12-15 minute time out allowed the unit to reset itself.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
The fan has to run if the compressor is running as the fan assists in removing the heat from the condenser coil. Can you spin the fan by hand? If there is full power(120 volts) to the fan and it isn't running then the fan motor is bad. Also, if the fan motor has a run capacitor this could keep the fan from running(if the capacitor is defective) so look for this first.
fan should turn off when compressor not running, the relay switch is stuck open for the fan, and probably needs replacing, but even if it always runs there is no harm and it only uses like 15 watts
I found the problem. Compressor is toast.
