Is 78 the 'Set' temperature, the desired temp to achieve, or the temperature of the pool water, according to the Heater?
Confirm actual temp of water via an accurate thermometer.
If set temp, simply push down arrow. Water has not yet reached the set temp.
If heater indicating 78, & water temp is actual 68, bad thermistor/temperature sensor.
Sounds like a faulty temp sensor. Check it for debris, clean it good and see if that does it. If not try replacing it.
