SOURCE: No image in view finder
Sounds like a defective CCD imager. You may be in luck. Canon should fix this for you for free, including free shipping both ways. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110
SOURCE: format button
When you set the Camera to Up load the Computer sees the camera as a drive and allows access-
Still with me.
Now go on line and download this program
www.pcinspector,
Install the program
When installed in the Start box diect it to the drive that is your 'Camera'
Then follow all the directions
Scargo - Take note
SOURCE: My Cannon Powershot SD1000 LCD screen does not work.
Has the screen been cracked/damaged? Was your camera dropped in any liquid? It's worth it to try having the LCD screen replaced, as it's quite affordable. If there is liquid damage near the LCD input inside the camera that would be another issue that would be solved by replacing those main boards.
In an ideal situation it would be just that the backlight cable wiggled itself out of its input (I'm assuming the screen doesn't light up anymore), which is something you could look at yourself if you're comfortable taking your camera apart. I wish you luck =)
The TV can be set up so that it can only be operated with
the remote control.
This feature can be used to prevent unauthorized viewing.
This TV is programmed to remember which option it was
last set to even if you turn the TV off.
Press the MENU button on the remote
control, then use the UP/DOWN arrow
button to select the Special menu.
Press the RIGHT arrow button to activate
the Special menu.
Use the UP/DOWN arrow button to
choose Key lock, then press the RIGHT
arrow button.
Use the UP/DOWN arrow button to select
On or Off.
Press EXIT button to save and return to
TV viewing or press the MENU button to
save and return to the previous menu.
the remote control.
Language
Main Source
PIP Source
Captions
Caption/Text
ARC
Key lock G
Auto Convergence
Auto Move
F Back Next G
SETUP
VIIDEO
AUDIIO
TIIME
LOCK
SPECIIAL
On
Off
With the KEY LOCK ON, the display
'KEY LOCK' appears on the screen if
any button on the front panel is
pressed while viewing the TV.
which option it was last set to
even if you turn the TV off. good luck
regards
shaun
