Https://assets.fluke.com/manuals/1ac_____iseng0100.pdf
Disabling the Audible Beeper Disable the beeper by holding the green button down for more than 2 seconds during power up. To enable the beeper again, turn the unit off, and then turn it on
The computer is on alert, a messenger to the user. Several computer features perform alert functionalities. First, the firewalls are feature functions on the computer that prevents any program least recognized as belonging to the system from integration. Alternately said, a firewall on the computer disallows any program installations either achievable with CDs, Disk or DVD media or simple downloadable from networked structure of devices. In the situation that external programs were being introduced by the user, a message alert is displayed either as warning of possible infiltration or requesting permission for progress. Second, the computer security settings usually prevent any unauthorized integration of programs into users default settings. In which instance, the user has to disable the computers security else downloads of program installations would be nonexistent. Third, internet worked computer device usually has security setting for several purposes. First, internet security setting on the computer allows the default user of the computer to gain access to networked device often common with subscriber connections. Once an authorized user is recognized, permission is acquired to navigate the network. Alternately, internet computer securities disallow intrusion programs. For example while on the internet, it is possible to request programs either irrelevant in functionality, harmful ware clogging computers features as default. Finally, internet security make impossible hidden intrusions on the from several device operating under auspices least observable above program encryptions. However, a computer alert performs as reminder to the user that an introduction of programs from an elsewhere location is about to take place. Usually, a popup logo would require authorization approval to continue with accessibility or authorization disapproval for alternate response to be achieved. In the situation of yahoo messenger installation alert would require disabling the computer firewalls if any installation the program may be required. A computer firewall set as enabled would hardly allow installations or downloads unless the feature was set to disabled by the computer user for resuming of program transferability.
Emergency Alert Mode
The Emergency Alert feature can be used to signal members in your
group of your need for urgent help. MR series radios will operate in an
automatic "hands-free" emergency control mode for a total of 30
seconds after activating the Emergency Alert. MR series radios in your
group will automatically advance the speaker volume to the maximum
setting and sound a warbling alert tone for 8 seconds. The alert tone is
emitted from your own radio speaker and the receiving radios in your
group. After the 8 second alert, any spoken words or incidental sounds at
your end will be transmitted to the group for 22 seconds. For the 30
second duration of Emergency Alert mode, MR series radio controls and
buttons will be locked to maximize reception of the emergency message.
1. Press and hold the Emergency Alert button for 3 seconds.
2. Release the button after the LED Indicator glows red and the alert tone
begins to sound. There is no need to continue to hold the Emergency
Alert button or use PTT for your message to be transmitted.
3. After the alert tone ends you may speak into the microphone. Your
voice or incidental sounds will be transmitted. The LED indicator will
continue to glow for the duration of the 22 second period.
4. After 30 seconds your radio speaker will emit a Talk Confirmation
Tone and the LED Indicator will extinguish. Operation then returns to
normal two-way mode.
Note: All Motorola Talkabout EM, MJ, and MR series radios are fully
compatible with the Emergency Alert feature. Radios other than EM, MJ,
MR series can receive the emergency alert signal, but will not respond
with adjusted volume settings, locked controls, or a warbling alert tone.
Users of other radio models set to the same channel and Interference
Eliminator Code will hear a steady tone for 8 seconds followed by the
voice transmission for 22 seconds.
Warning: The Emergency Alert feature should only be used in the event
of an actual emergency. Motorola is not responsible if there is no
response to the emergency alert from the receiving group.
Here is a link to the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/MR350-351%20User%20Guide%2012-16-08%20KEM-PK14190-90.pdf
Best regards.
