Question about HP Officejet Pro 8600
How do I replace the yellow ink cartridge? - HP Officejet Pro 8600
  • 45 Answers
Open up the Panel It has the writing HP office jet pro Etc. on it, then the cartridge/head will move toward you, push in on the yellow cartridge until it clicks and release it will disengage and you can remove old cartridge.
Installation is exactly like removal insert new cartridge until it clicks release and it will engage.
Close panel and the cartridge/head will move back to previous position
Posted on Jun 02, 2015
    New Friend:
  • 9 Answers
26.001 error hp 4000
26.0:01 is a bad contact in the Ink Supply System for the yellow ink cartridge. (This can be caused by using non HP OEM ink)
Check that the ISS to Cartridge cable is not damaged and is fully connected to the Ink Supply Tubes PCA.
You can also try switching the magenta contacts with the yellow contacts and see if the problem stays with the yellow, or you now have a magenta problem.
If the problem stays with the yellow, then you will need to replace the Ink Supply Tubes and Trailing Cable.
If the problem moves to the magenta, then you just need to repair or replace the contacts (may just need cleaned)
Good luck !
(My money is on bad compatible or refilled yellow ink cartridges)
Apr 12, 2013 | HP Designjet 4500ps InkJet Printer
Im using hp deskjet 2660 cartridge says INTRODUCTORY HP TRICOLOR PRINT CARTRIDGE (colors) cyan magenta yellow 60 it's not producing yellow images that i printed are in pink or purple i...
This model printer has only two slots for ink cartridges. One is for a black ink cartrigde and the other is for a tri-color cartridge which contains cyan, magenta and yellow inks.
This tri-color cartridge has run out of yellow ink, you need to replace this tri-color cartridge.
Aug 12, 2011 | Office Equipment & Supplies
I have a HP Officejet Pro L7680 and have enjoyed a year of problem free use. Now the printer says "Ink Cartridge Problem" :The following ink cartridge appears to be missing or damaged" ...
Hi
You need to replace the Yellow cartridge
with a new one couse the old one either
has expire or has problem with the chip
on cartridge
ps vote us to keep us alive
Nov 06, 2010 | HP Officejet Pro L7680 All-In-One InkJet...
Windows Ink Cartridge Empty false error message.
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Oct 28, 2009 | HP C6280 All-in-One Printer
Epson Stylus shows out of ink with full cartridge
it is the problem your printer head change it and then solve
Jul 13, 2009 | Office Equipment & Supplies
Says the yellow ink needs replacing,have a new ink cartridge in
pulled plug, removed yellow cartridge, cleaned point where yellow ink goes in, put plug back in and it worked.........Thanks
Jan 27, 2009 | Brother MFC 210C All-In-One InkJet Printer
Don't know how to move the cartridges to replace the ink.
Please follow the instructions below to ensure correct installation:
  1. Lower the printer's output tray and open the top cover.
  2. Connect the power cable to the printer.
And switch on the printer.
The print heads will now move to the replacement position. If they do not move to a change position press the Red ink button on the printer.
  • Lift up the ink cartridge clamps.
    Before you open the new ink cartridge package, shake it four or five times. Then remove it from the package.
    Do not touch the green chip
    on the side of the cartridge. This can damage the ink cartridge.
    Remove the yellow tape from the bottom of the ink cartridge.
    You must remove the yellow tape from the cartridge before installing it; otherwise, print quality may decline or you may not be able to print.
    If you have installed an ink cartridge without removing the yellow tape, take the cartridge out of the product remove the yellow tape, and then reinstall it.
    Do not remove the transparent seal from the bottom of the cartridge or the label on the cartridge; otherwise the cartridge may become unusable or ink will leak.
    Place the ink cartridge into the cartridge holder with the bottom down. Then push down the ink cartridge until it clicks into place.
    Repeat steps 4 to 6 for each ink cartridge.
  • Close the ink cartridge cover and press it until it clicks into place
      If you find it difficult to close the cartridge cover, make sure all the cartridges are firmly seated. Press down on each cartridge until you hear it click into place. Do not attempt to force the cover closed.
    1. Close the printer cover and press the ink or start button to begin charging the system. Charging can take up to three minutes and is complete when the power light stops flashing.
    While the ink system is charging do not switch off the printer.
    Sep 16, 2008 | Epson Stylus 880 InkJet Color Printer
    Color
    Recheck the placement of the ink cartridges. The black ink cartridge is larger; the cyan, magenta, yellow cartridges are all the same size.
    When the ink cartridges were replaced, two or more may have been inadvertently switched or an extra yellow cartridge placed in.
    Aug 04, 2008 | Canon BubbleJet i560 InkJet Printer
    HP Officejet Pro 8600 Logo
    162 people viewed this question
    Clive
    Clive
