Question about Sewing Machines
Singer Quantum CXL: After I use the reverse button and release it, the machine does not go back to stitching forward. It stays "stuck" in reverse until I turn it off and back on again. :-( ?
  • Sewing Machines Master
  • 1,860 Answers
the reverse mechanism is not releasing to go back to its normal forward position. if you do not have pressure on the reverse button and it feels like there is some slack with no tension on the button, the mechanism has not returned to the forward position. there may be a spring that has the end broken off to keep tension on the reverse mechanism,, it would be a good idea to have the machine checked to see what the problem is.
Posted on Jun 04, 2015
SOURCE:
Cxl manual
User's Manuals, including yours, are available as a free download the Singer Sewing Machine website. Actually, when you enter CXL you get the XL-50 user's manual, which is essentially the same machine, although a few of the patterns may be different. The CXL, XL-50, XL-10 and XL-1 are basically the same machine; I own a CXL and XL-50, and love them. They can sew SIDEWAYS--straight AND zigzag stitch!
Jun 12, 2014 | Singer Sewing Machines
Singer Quantum Stylist 9960 {error message > release reverse button )
It is either defective or received shipping damage.
May 16, 2014 | Sewing Machines
I am having the same problem as angelmdb.. I have a new computerized futura and am trying to just straight stitch with it.. it starts off fine for about 8 stitches then beeps and stops.. i wait it will do...
Go to singerco.com and under customer support, look at frequently asked questions, they have alot info there. If, that doesn't work for you, call customer service at 1-800-4singer and they can advise you
Sep 20, 2010 | Singer CE-200 Quantum Futura Computerized...
How do I reverse stitch on a singer 362 fashion mate model
The large knob in the center of the stitch length dial is a button, push it in to reverse stitch. Hold in as long as you need to reverse stitch, then release to resume regular stitching.
Jan 09, 2010 | Singer Sewing Machines
Reverse stitching on a singer 514, HELP!
In the center of the stitch length knob (at the right side of the machine) is a button. You would push that button in to get the machine to reverse.
May 08, 2009 | Singer 7442 Mechanical Sewing Machine
I have a quantum cxl. It will sew normal stiches but it will not sew the decorative stiches
The needle shaft sticks to the curved arm and won't come down because a piece of plastic, about an eighth of an inch thick had broken from age. It prevented the shaft from staying up on the needle arm. Open the cover, try to stitch decorative stitch and see what I mean. Purchase a package of 4-10 by 1/2 nut and bolt pack. Screw the nut all the way onto the bolt. Using needle-nosed plyers, Carefully bend the curved arm slightly, and place bolt into the hole on the top of the needle shaft. Nut will keep it in place. Lowering the needle shaft using wheel, carefully bend arm back in place. Try decorative stitch. It should work. It does for me.
Aug 03, 2008 | Singer Quantum XL-1000 Computerized Sewing...
Machine sews only in reverse
Be sure you are in the correct stitch pattern...if you are on a buttonhole stitch or a stretch stitch it normal for the machine to sew backwards. Be sure your length is to the right of 0 and not in a strtch stitch model or buttonhole mode.
Bonnie
Jul 28, 2008 | Kenmore 15218 Mechanical Sewing Machine
Sewing Machines Logo
62 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
