Hi Fernando, you put the brand and model of your radio, but do not indicate what problems you have
Comment what you need, so I can give you some idea
I wait your answer
Greetings Franco Dosil
Hola Fernando, pones la marca y el modelo de tu radio, pero no indicas que problemas tiene
Comenta que necesitas, asi podre darte alguna idea
Espero tu respuesta
Saludos Franco Dosil
Hola Dave LaDue, siga las instrucciones que sugiere Jelyce Tsai, son correctas, lea la p?gina 7
del manual del usuario y siga los pasos para pasar de la separaci?n de 9Khz a 10Kzh en AM
Hola Dave LaDue, sigue las indicaciones que te indican Jelyce Tsai, son correctos, lee la p?gina 7
del manual del usuario y sigue los pasos para pasar la separaci?n de 9Khz a 10Kzh en AM
I have the same issue with my Sangean WFR-28c. I just contacted support (through Sangean Europe site) but im still wating for an answer. If this carries on, i cannot use this radio. :(
I have similar problem with this set - recordings are corrupted. Every few seconds a fraction of a second is cut off. Probably it's a problem with SD card. Someone reported this problem in amazon.com customer review for Kingston 4 GB Class 4 SDHC Flash Memory Card SD4/4GBET
Remove the battery compartment door and the batteries. There should be a small hole marked "reset" under the upper battery cradle. Press (gently...until it clicks) and hold for 5 seconds. Replace batteries and try again.
