I hear you saying everything seems fine with your oven except there is no heat action, Is that correct?
In my experience, the trouble can be traced to a faulty micro switch in the door safety interlock system as the #1 trouble.
Please remove the cover - use care to not touch the silver can - find the micro switches on the side away from the hinge.
You can test these switches with a volt/ohm meter in contunity setting. Test each switch independently.
What frequently happens is these switches become burned from arcing due to the door being opened while the oven is operating. The purpose of these switches is to tell the oven the door is closed and it is OK to turn on the magnatron. If the switch is burned, (fails to make a contact) the oven thinks the door is open, door open, no heat ... Make sense?
Find replacement switches at a FixYa.com advertiser, a local appliance parts place or at
www.repairclinic.com
This is not the only reason for a oven to not heat ... if this problem persists, please post a note here.
Thanks for using FixYa.com
a
