Re: I am looking for samsung Power-Supply signal board...
You will likely need a new tv. Changing the power board helps about 20% of the time. The other 80%, lightning skips into the antenna/tuner and knocks out those circuits as well.
I found the board (power supply signal board) replaced it and the tv is working like wonders. Thank youI found the board (power supply signal board) replaced it and the tv is working like wonders. Thank you
You can't post conmments that contain an email address.
I didn't pull up the manual on this set but if since its a LCD set and the power board didn't fix it I'd look to the inverter board unless its built into the PS
The power supply board of the television is dead,do you know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
90% to 95% ur tv have a dead power supply board only.5% ur tv could have both dead boards the tv power supply board and the main tv Tuner signal board too.The tv power supply board.That the board,where the power a/c cord plug into it.The tv main Tuner signal board,that the board where all the exstented devices and the tv incomming broadcasting signal cable wire plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement first.The tv problems should be fixed.If not than the main tv Tuner signal board is dead too.Must be replaced also.
This tv problems u have are only can be causes by only two boards 90% lightly it is the tv power supply board.5% it could be the tv Tuner signal board.5% could be both boards are dead require changes both boards.The tv power supply board it is the board that where the tv power a/c cord plug into it.The tv Tuner signal board it is the board that where the incomming broadcasting signal cable wire plug into it.Tries websites like Shopjimmy.com,Ebay.com to by a whole refurbishes power supply board or tv Tuner signal board or both.
When massive power surges to the tv.The tv Tuner signal board have 50/50 chances also dead too.In ur case it did.That the board,where the incomming broadcasting signal cable plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Take the tv aparts.The tv power supply board is dead.That the board,where the power a/c cord plug into it.That the power supply board it dead.Tries the websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
This tv still under warrenty?Call Samsung for service.Ur tv the power supply board is dead.That the board where the power a/c cord plug into it.That is ur tv power supply board and is dead.It must require replacing.Tries websites like Shopjimmy.com,ebay.com to buy a refurbish power supply board for the replacemnt,if the tv is out of warrenty.
Normal
0
false
false
false
MicrosoftInternetExplorer4
st1\:*{behavior:url(#ieooui) }
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Ur power supply board is dead, u know basic electronics’ and soldering?
Most of the times, the power suppply board just have dead leakages gases
capacitors.These capacitors alway bulges up on it top,or puff up on it
top.Replaced these gases leakages capacitors will get ur tv power stable,and
rerfurbish power supply board for the replacement.
