Possible that the drain pump is running due to a small leak is present at the base of the machine, providing this has a metal cover on it ,it gets water in here which activates afloat switch switching on the pump hence draining the machine to avoid possible flooding, if the pump does not appear to be running then the drain hose is too low resulting in syphon effect,in which case raise it...Good luck
SOURCE: My brand new Bosch is not draining and is showing E:13 error code
Put the washer on cold and run "TWO" cycles. There is too much soap or fabric softner.
SOURCE: Bosch Error Code 13 Washer won't drain
First, unplug your washer. After that find the little round plate below your drum opening on the exterior of the washer. It should have a small hole in it. Use something to gently push trough this hole and twist the cover off, Inside there you will find the drain access. Be careful, if there is water in your drum this will make a mess when you unscrew the drain access. Take the usual precautions and unscrew the drain access slowly until it is off. Remove any obstructions and replace access door and cover. Clean up any mess and plug back in your washer and try again. takes about thirty minutes to an hour depending on how much water is in the drum.
SOURCE: Bosch Nexxt 300 has error
Turn the dial to off position wait few second, door should unlock. Unless you try to open it during cycle, it won't open. Otherwise, follow owner manual. call the manufacture.
SOURCE: Bosch Nexxt 300 series WFMC2201UC
You can check the inlet valves with either an o'scope or a multimeter. Unfortunately, the control module PN: 661081 controls the voltage to the inlet valves and costs around $240.
Sorry, to give you the bad news.
SOURCE: E04 error code, washer wont drain, water left in tub on a Bosch Nexxt 300 series
http://applianceguru.com/attachment.php?id=2463
Make sure you click helped, if helped that is.
