Life Fitness 9000 Next Generation Treadmill  Logo
Posted on Jul 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Every time I am setting up my routine I put my weight and then select manual and select time,when I ever put the minutes,it gives me an invalid time,although always put less than 60 minutes thanks
Anonymous
Level 3:
President:
  • Master 1,126 Answers
  • Posted on Jul 11, 2009
Anonymous
Master
Level 3:
President:
Answers
1126
Questions
0
Helped
563480
Points
3418
Http://us.home.lifefitness.com/content.cfm/ownersmanual
You can possibly find your model here for owners manual.
Invalid height and weight in set up
Apparently Fitbit was developed outside of the U.S. and does not understand American weights and measures. Convert to centimeters for height and kilograms for weight
How do I adjust the settings on a 625-236 atomic clock
If you have a Howard-Miller 625-236 atomic clock, do you need to change the time zone only or manually set the time?
To set the time zone, press Mode (furthest left on the back of the clock) to get to the Alarm Time Mode. Then press Set (2nd from the left) to change the time zone. Then press Adjust (the middle button) to select the correct time zone. Press Mode again to exit the settings mode. To manually set the time, you need to remove the battery from the clock. Then reinsert the battery after 30+ seconds. Press and hold Set until the hour begins to flash, then press Adjust to change the time. Press and hold to quickly change the hour. Then press Set to change to the minutes and use Adjust to set the current minutes. Repeat this routine to set the seconds, month, date and year. Press Mode to exit to the Time mode.
The manual is available here: http://www.theclockdepot.com/howard-miller-625-236-techtime-operations-manual.pdf .
I hope this helps.
Oct 06, 2014 • Home
LG kg 300 sim invalid and registration failed?
try to reset factory settings by 2945#*# and select factory settings.this will solve, if problem persist make sure if your SIM is compatible to your device (this happen many times when SIM is old and not 3G configured, maybe it is work on another device but this device will reject).
3helpful
I need a manual for the royal tc 100 time clock
Program the Date & Time and Print Method using the 3 buttons: Mode, Select, Setting:
Date & Time: Press the Mode button. The Hour will start blinking. Press the Setting button
until the correct hour is displayed. Press Select to set the hour shown.
The Minutes will blink. Press Setting until the correct minutes are displayed. Press Select
to set the minutes shown.
The Seconds will blink. To set the seconds at 00, press the Setting button. Press Select.
The Year will blink. Press the Setting button until the desired year is shown. Press Select
to set the year shown.
The Month will blink. Press Setting until the correct month is shown. Press Select to set
the month shown.
The Day blinks. Press Setting until the correct day is shown. Press Select to set the day
shown.
Print Method: Press the Mode button until P5 (Program Mode 5 for Print Format) is displayed.
Press Setting to choose one of the following Print Methods.
The TC100 has two settings for print activation: Manual or Automatic
1 = Automatic (default setting) - The TC100 automatically prints when the time
card is inserted.
2 = Manual - After inserting the time card, press the Print Button to activate
printing.
Press Select to confirm the Print Method chosen. Press Mode to return to normal operational. hope this work for you best regards happy holidays : - )
I have an HE 5T Steam Front Loading Automatic Washer. It is showing Sud indication, nothing seems like happening and after few minutes it will show F35. What does it mean?
Hello again,
I found your manual. If you like to get it, go HERE. This is what it says about "SUDS" action:
"SUD" (Suds Routine) When excessive suds are detected, a suds routine automatically starts. This routine removes extra suds and assures proper rinsing of your garments. "SUD" is displayed during rinsing to inform you that Suds Routine was activated. Use only HE (High Efficiency) detergents.
Near the bottom of the troubleshooting page, it gives this for errors:
"F" Codes other than F20, F21 and F22 Select STOP twice to cancel the cycle. Select DRAIN & SPIN if there is excessive water in the washer. Re-select cycle and press START. If the problem remains, call for service.
It doesn't specifically state what "F35" is, so I can only suggest these steps, and see if this solves your problem. If it doesn't I would be inclined to believe that there is a problem with a part, which would probably be serviceable by a tech from Sears or their partner service company.
Hope this clears it up for you.
Please rate and comment. Thank You
Joe
I dont know how to set the clock
Setting the clock
Use these instructions to set the clock.
1 Use MULTI-CONTROL to select Clock.
2 Push MULTI-CONTROL left or right to
select the segment of the clock display you
wish to set.
Pushing MULTI-CONTROL left or right will select
one segment of the clock display:
Hour-Minute
As you select segments of the clock display
the segment selected will blink.
3 Push MULTI-CONTROL up or down to
put a clock right.
Note
You can match the clock to a time signal by
pressing MULTI-CONTROL.
! If the minute is 00 to 29, the minutes are
rounded down. (e.g., 10:18 becomes 10:00.)
! If the minute is 30 to 59, the minutes are
rounded up. (e.g., 10:36 becomes 11:00.)
Here is a link to the online Manual: http://a248.e.akamai.net/pix.crutchfield.com/manuals/130/130dehp690.pdf
Everytime you put your card in, you have to move the dial on the side to say in our out on your shift?
this should fix your problem
HOW TO USE YOUR TC100 TIME CLOCK Step 1: Remove the front cover - see enclosed instruction sheet on page 5. Step 2: Program the Date & Time and Print Method using the 3 buttons: Mode, Select, Setting: Date & Time: Press the Mode button. The Hour will start blinking. Press the Setting button until the correct hour is displayed. Press Select to set the hour shown. The Minutes will blink. Press Setting until the correct minutes are displayed. Press Select to set the minutes shown. The Seconds will blink. To set the seconds at 00, press the Setting button. Press Select. The Year will blink. Press the Setting button until the desired year is shown. Press Select to set the year shown. The Month will blink. Press Setting until the correct month is shown. Press Select to set the month shown. The Day blinks. Press Setting until the correct day is shown. Press Select to set the day shown. Print Method: Press the Mode button until P5 (Program Mode 5 for Print Format) is displayed. Press Setting to choose one of the following Print Methods. The TC100 has two settings for print activation: Manual or Automatic 1 = Automatic (default setting) - The TC100 automatically prints when the time card is inserted. 2 = Manual - After inserting the time card, press the Print Button to activate printing. Press Select to confirm the Print Method chosen. Press Mode
17helpful
3answers
Whats the admin password for scx 6545n
The initial administrator's setting is as follows: • The default ID: admin • The default password: sec00000
2answers
How to set the time and date
I have read through the manual and could not find any special action required the register the change.
The only thing that I can think of is, did you continue to press the "select" button until you have left the time set routine? If you do not exit the routine then it seems likely that changes will not be recorded.
Top Life Fitness Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Mike Cairns
Mike Cairns
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
