Coffee Makers & Espresso Machines Logo
A
Anonymous Posted on May 31, 2015
Where can i purchase a replacement sprayer head for a bunn btx b coofe maker
Padre Castens
Level 1:
New Friend:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Nov 16, 2015
Padre Castens
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
7
Questions
0
Helped
8435
Points
10
You would need to go to the Bunn website.
5 Related Answers
Anonymous
  • Posted on Jul 29, 2009
SOURCE: I pour water in my Bunn VPR coffee maker and it
your coffee maker should have come with a 3/16 " spring that is tapered on both ends. unplug the coffee maker. unscrew the sprayer and insert the spring into the hole. push and turn the spring until it reaches the tank opening the line. after getting the line open you can run vinegar and water solution to help clear out calcium deposits.
Terrry
Anonymous
  • 189 Answers
  • Posted on Jun 28, 2010
SOURCE: Does Bunn have a design problem with the BTX-B
If you will give Customer Service a call, we will be happy to assist you with this issue. 800-352-2866 is the toll free number.
Anonymous
  • 189 Answers
SOURCE: MY BUNN COFFEE MAKER MODEL BTX-B BREWS SLOWER THAN
To clean your brewer, pour in 1 qt of white vinegar into the top, place the carafe on the base and close the lid. Allow the vinegar to sit in the machine for 2 hours. After 2 hours, turn off the machine and let it cool. Then remove the sprayhead and insert the metal spring(deliming tool) into the hole where the sprayhead was and twist it 5-6 times. Then you will flush out the machine by pouring 8-10 carafes of water through the machine.
Anonymous
  • 1637 Answers
  • Posted on Jan 21, 2011
SOURCE: dry coffee is left in funnel after brewing.
The fastest and most cost efficient way to fix this issue with HEAD SPRAYER HOLE clogging is to run vinager through the system several times. The compounds in the vinager serve as a cleaning agent to clean the heads naturally and allow the coffee to travel once again in the same holes it did when you first purchased the unit!!! Just fill up the pop with straight vinager and allow it to run through the system just as if it was coffee! This WILL NOT have any harmful affects to you or the coffee system unless you are allergic to vinager.
Anonymous
  • 115 Answers
  • Posted on Sep 24, 2011
SOURCE: bunn-o-matio model btx-b does not heat water
Hi, Sounds like a boiler therostat or faulty boiler. Dazza REPAIRER
I have a Bunn BTX-B. It just stopped heating the water. I received it as a Christmas gift, purchased on Dec. 24, 2010, from Lowes. I do not have the receipt. I emailed customer service. They sent me two...
Warranty is 1 year parts and labor, 2 years parts only and 3 years for control boards. That model does not have a control board. You could have a bad thermostat, bad high limit, bad thermal link or bad element. Without you having a multimeter anSd the knowledge of how to use it properly it would be best to replace the unit.
Repairing Bunn BTX-B - Popping the GFI Breaker
the screws are under the flip lid where you ad water. sounds like your heating element is shorted most common problem with the bunn not hard to replace call bunn for replacement or order on line. hope this helps you. .lee
Bunn-o-matio model btx-b does not heat water
I am moving and need to empty the water out of my bunn how do i do that?
Hi - Unplug your machine and let the water cool; unscrew the sprayer head, then turn the machine upside down over your sink. The water will drain from the hole where the sprayer head screws in.
Hope this helps!
Top Bunn Coffee Makers & Espresso Machines Experts
vince
john h
ADMIN Andrew
ADMIN Andrew
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
